Which Turbo?? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Which Turbo?? (/showthread.php?tid=5133) |
Which Turbo?? - CJ_Derv - 25-07-2012 I know many will have probably asked this a million times on here, BUT wondering if can get enough opinions to make up my own mind about which turbo to keep on or put on this weekend.. Options atm are 1. Garrett T2 ( has very slight play in shaft which i believe is ok) 2. KKK K14 already fitted Now the K14 after nipping the intake manifold up till i fit new gasket hit 28psi last night but manifold is still leaking T2 hasnt ran over 24psi on the Blaze i had on Modded Bosch pump Any opinions welcome just want to know which to go for untill i source another TD04 or similar as TD04 had hidden damage inside so gone back Cheers CJ RE: Which Turbo?? - Midnightclub - 25-07-2012 T2 is the one most people recommend but tbh if anything i'd say k14 is just as good and just as durable, i know people have had them at 30'odd psi for quite some time before they've gone pop RE: Which Turbo?? - Ruan - 25-07-2012 K14 is the "biggest" turbo... IMO it'll produce the most power on an XUD... For the best compromise between response and power, the T2 is generally accepted as the best turbo... Also because of the wastegate design, it's easier to eliminate creep at high pressures... I personally wouldn't change one for the other, the advantages of one or the other barely outweigh the ballache of changing it... If it possibly has shaft play, I wouldn't bother, you'll kick yourself if you blow it... As said, I made 146shp and 250flb.ft with a K14.... There's other restrictions on these engines that need fixing before instantly branding a turbocharger as "shit" like some people do... RE: Which Turbo?? - CJ_Derv - 25-07-2012 (25-07-2012, 02:15 PM)Ruan Wrote: K14 is the "biggest" turbo... Cheers Ruan i think im going to stick with the K14 as should only be a month or so til get a TD04 or equiv sorted ![]() I think ive eliminated the possibility of a hose leak as nipped intake bolts a tad without being able to get my stupidly huge forarms behind the engine until this weekend. i would imagine there would be significant signs from a leak ie slight oil slick etc But will be sticking with K14 have got MBC on now so should be all good with new gasket aslike mentioned pulled reasonably well at 28psi til i heard the manifold go a bit then bellowed black out so backed off at 4k lol CJ RE: Which Turbo?? - silverzx - 26-07-2012 Did you have to drop the engine forward to get to the manifold bolts? Are they an allen key or? Planning on taking turbo & manifold off a car tomorrow so would be helpful to know! RE: Which Turbo?? - 4WayDiablo - 26-07-2012 (26-07-2012, 05:24 PM)silverzx Wrote: Did you have to drop the engine forward to get to the manifold bolts? Are they an allen key or? Planning on taking turbo & manifold off a car tomorrow so would be helpful to know! Best take it of the mounts and drop forward slightly. You mainly need the room to get the turbo out Usually 5.5mm Allen keys iirc? RE: Which Turbo?? - CJ_Derv - 26-07-2012 Havent got round to changine it but 5.5 or 6mm alen keys iirc and 13nuts on the turbo and ends of my manifold RE: Which Turbo?? - silverzx - 26-07-2012 Cheers lads! |
