 EGR help - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: EGR help (/showthread.php?tid=5059)  |
EGR help - Slam Wagon - 22-07-2012 I know its another egr thread but am i looking at the right thing here? The piece with the two pipes leading into it? If so when i remove it where do these pipes go?! Here is a pic ![]() Cheers for the help. RE: EGR help - Poodle - 22-07-2012 Yes, you are looking at the EGR. Those two pipes feed coolant into a heat exchanger incorporated into the EGR system, you can bypass it just by joining the two. I used a bit of copper pipe myself, worked fine. RE: EGR help - Slam Wagon - 22-07-2012 Awsome, did you get yours out with the engine still in place? I cant even reach the bottom bolts let alone get a tool to them RE: EGR help - Poodle - 23-07-2012 Hahaha, have done before, yeah. It's a proper bastard of a job though, have to come at it from several different angles, think it took me about 4 hours! Oh and you'll want to remove the top engine mount bracket so you can roll the engine forward for better access. RE: EGR help - Slam Wagon - 23-07-2012 Awesome, this is what i was thinking of doing. Cheers for the help.  |
