powersteering - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: powersteering (/showthread.php?tid=4979) |
powersteering - simonx3 - 18-07-2012 Hey can anybody help when i start up the car theres a sqeeking noise cumin from engine bay and sounds like cuming from the powersteering pump has anybody seen this and could help RE: powersteering - 4WayDiablo - 18-07-2012 Its certainly possible. Could get a video up for noises. Should be fairly obvious where it cones from just poke about RE: powersteering - Danny2009 - 18-07-2012 Does the noise go away when its warm? could be the aux belt. RE: powersteering - simonx3 - 18-07-2012 Na stays on all time RE: powersteering - puglove - 18-07-2012 spray a load of WD40 on the fan belt, if it stops then its that and it will need replacing lol RE: powersteering - Niall - 18-07-2012 Or just take some tyre chalk to the inside of the belt when it's running. But for the sake of 9 quid and 30 seconds work, could just replace the belt. RE: powersteering - simonx3 - 18-07-2012 Tryed wd40 and didn do anything lol RE: powersteering - Niall - 18-07-2012 Try a new belt and if it's not that, with the car running, put a screw driver to the pump and put the other end to your ear and you will be able to hear it if it is that. Could also be the alternator RE: powersteering - simonx3 - 18-07-2012 Ok bit strange but ill give it ago lol its starts fine evrytime so wouldn fought alternator RE: powersteering - Niall - 18-07-2012 Nah it's not strange. It acts the same way as a stethoscope. Great for pin pointing noises. What engine is it btw? RE: powersteering - simonx3 - 18-07-2012 Its the 1.4 meridian |
