 what do you think my old pump had done to it? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: what do you think my old pump had done to it? (/showthread.php?tid=4883)  |
what do you think my old pump had done to it? - Joe - 15-07-2012 right since ive owned my new d'tub ive been wondering what on earth my old pump had done to it, it would continue revving right round to 5700 ish rpm and you wouldnt notice that it wasnt pulling anymore, what do you think has been done to it? RE: what do you think my old pump had done to it? - Dan! - 15-07-2012 A stock pump will rev that far in first and second but there would be a significant drop in power. Sounds like it has been gov modded tbh RE: what do you think my old pump had done to it? - Joe - 15-07-2012 it would do that in every gear! fancy taking a look dan? RE: what do you think my old pump had done to it? - Mattcheese31 - 15-07-2012 as Dan says, it had been Gov modded . .
RE: what do you think my old pump had done to it? - Ruan - 15-07-2012 Bosch or Lucas... If Lucas, it's an old style one that revs like f*ck when you turn it up. RE: what do you think my old pump had done to it? - Chris - 15-07-2012 Yea my lucas was the same, limiter was around 5.8k with a very light s1 tune, and the throtle stop removed. RE: what do you think my old pump had done to it? - WiNgNuTz - 15-07-2012 (15-07-2012, 01:25 PM)Chris Wrote: Yea my lucas was the same, limiter was around 5.8k with a very light s1 tune, and the throtle stop removed. Hmm....what throttle stop would this be? is it easy to remove? Ive turned the fuel up on my Lucas, making 18-19psi, but there is, as Dan! puts it, a significant drop in power at about 4.5k.... RE: what do you think my old pump had done to it? - Chris - 15-07-2012 Its the screw/ bolt the throtal arm rests up against. Don't remove it completly, and make sure the throtal works as it should. Also adjust the cable end on the arm so you actualy get full travel. RE: what do you think my old pump had done to it? - Tom - 15-07-2012 (15-07-2012, 01:44 PM)WiNgNuTz Wrote:(15-07-2012, 01:25 PM)Chris Wrote: Yea my lucas was the same, limiter was around 5.8k with a very light s1 tune, and the throtle stop removed. The screw on the throttle arm, pull it to full throttle with the engine off obviously and it'll hit a screw i you wind that out it can go further ![]() Edit: Chris beat me
RE: what do you think my old pump had done to it? - WiNgNuTz - 15-07-2012 Hmm....i might go have a look at this now.... RE: what do you think my old pump had done to it? - Dan! - 15-07-2012 Yours will be a new style Lucas Steve, they will rev pretty shit no matter what you do... RE: what do you think my old pump had done to it? - WiNgNuTz - 15-07-2012 (15-07-2012, 03:16 PM)Dan! Wrote: Yours will be a new style Lucas Steve, they will rev pretty shit no matter what you do... Meh, goes to up 5k now, feels a little strained once its there, but it gets there. Probably wont be taking it that far very regularly!
RE: what do you think my old pump had done to it? - Jarrus - 15-07-2012 I got an old style RotoDiesel Lucas on my XUD7TE 205, so you reckon with more fuel it will rev it's tits off? btw it's un modded thus far... RE: what do you think my old pump had done to it? - Joe - 15-07-2012 no its a bosch   but i may have a play with my lucas tomorrow want some more power now!
