Clutch :( - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Clutch :( (/showthread.php?tid=4273) |
Clutch :( - strictly_perv - 18-06-2012 As some of you know, I took the 205 on the dyno and the clutch got raped. It was fine before but now it slipped it 3rd on blow. So definatly a new clutch time. Just after some opinions on what to get now as I'm torn between a paddle or a good old valeo. I'm not really hunting for more power as it does go as it is (doesn't mean I won't ). I'm pretty skint ATM so won't be able to get anything fancy.The other thing is the box. After the journey up to FCS i've realised it's stupidly short at cruising speeds. I have a 306 DT box sat in the garage so don't know whether to chuck that on a get a HDi box. What do you lot think anyway?. RE: Clutch :( - Ruan - 18-06-2012 No HDi boxes IMO, DT is the longest I'd go, HDis mean you end up off boost every gear change... RE: Clutch :( - strictly_perv - 18-06-2012 Are you running the standard box? RE: Clutch :( - darrenjlobb - 18-06-2012 Imo id put a DT box on it with one of the cheaper CG paddle clutchs... Unless you WANT good economy and prepared to sacrafice some "fun" then go with the hdi box...but DT box is good enough on long runs, and a better box in general.. The CG clutch is a cheap clutch, and in some respects it shows, but ive had mine on my last two engines, and given it left foot HELL, and its still going...and never slips...so worth it imo... RE: Clutch :( - Ruan - 18-06-2012 Yeah, I just run a standard DT box. RE: Clutch :( - Chris - 19-06-2012 The CG unsprung paddle and pressure plate is £200 delivered I believe. The plate by itself is ~£140 delivered. RE: Clutch :( - td_dan - 19-06-2012 max go for a dt box mate, with 1.9 gti driveshafts accompanied with the 306 inner cup should work a treat although you might have to change the hubs aswell RE: Clutch :( - strictly_perv - 19-06-2012 Thanks for help people. Can anyone link me to the 306 paddle clutch? Can't seem to find the right one unless i'm being an absolute mong. Dan can the original 205 DT shafts fit in the box? RE: Clutch :( - ash23 - 19-06-2012 this is the one im going to be using max if you phone up they normally do them for 220posted inc vat. http://www.clutch-specialists.co.uk/auto/PEUGEOT-306-1-9-TD-04-93-07-98-performance-clutch-kits http://www.clutch-specialists.co.uk/car/competition-clutch-kits RE: Clutch :( - strictly_perv - 19-06-2012 Cheers Ash. I'm now abit stuck on what set-up to go for for the 205, because the 205 is originally a push type where as the 306 is a pull. Or is it the otherway round? ![]() Either was is it possible to just put the whle box on the 205 with the 306 clutch for ect? RE: Clutch :( - darrenjlobb - 19-06-2012 Just use the 306 setup fella, altho all the 205's ive had apart are that anyway...either way id just use a 306 tranny / clutch fork etc... If you email the guy at CG they pretty much instantly half the price, the web listing price is double what I ended up paying... The pressure plate it comes with is just a stock AP one also, but unless you have another brand new one, buy it anyway. RE: Clutch :( - strictly_perv - 19-06-2012 Think I'm just gunna go for that then. If it can handle your engines it must be good! I'll give them a call tomorrow and see what they can quote me. RE: Clutch :( - td_dan - 19-06-2012 when i checked they seemed to fit but i cant remember to be honest mate, the 205 dt ones are the same as the 1.6gti ones so just a case of checking them again but i havent got any at the min
RE: Clutch :( - darrenjlobb - 19-06-2012 Like i said, Mine is pretty destroyed, but I had no money so had to put it back on, but half the friction plate is on the flywheel / pressure plate, still working ok for now though! They do judder pretty bad though without springs. RE: Clutch :( - Ruan - 20-06-2012 Max, I do wonder if infact your gearbox isn't a 1.9DT one, whether actually it is a 1.9GTi box, it'd make more sense like that - it could have been replaced before, as I've heard that the XUD7 box is identical to the XUD9 box? Hmm... RE: Clutch :( - strictly_perv - 20-06-2012 Ruan that would explain the high revs. And a spare plug lying round. Just rang C.G clutch's and the best they can do is £230 for a 3-piece kit rated to 200bhp. I mentioned that a friend payed alot less and he said he very much doubts that
RE: Clutch :( - Carlos182 - 20-06-2012 (20-06-2012, 10:35 AM)Ruan Wrote: Max, I do wonder if infact your gearbox isn't a 1.9DT one, whether actually it is a 1.9GTi box, it'd make more sense like that - it could have been replaced before, as I've heard that the XUD7 box is identical to the XUD9 box? The 205 DT I had was like Max's... Revs silly high on the motorway. Much shorter than a 306 one... RE: Clutch :( - strictly_perv - 20-06-2012 Been looking at the money situation and might just have to get a Valeo one. I can get one for £96 at the local car place. RE: Clutch :( - ginge191 - 20-06-2012 (20-06-2012, 05:52 PM)strictly_derv Wrote: Been looking at the money situation and might just have to get a Valeo one. I can get one for £96 at the local car place. you are putting the 1.9 DT box on at the same time, yes? RE: Clutch :( - strictly_perv - 20-06-2012 Yes this box was pretty tragic on the FCS journey RE: Clutch :( - ginge191 - 20-06-2012 (20-06-2012, 06:02 PM)strictly_derv Wrote: Yes this box was pretty tragic on the FCS journey this is true.. i had to slow down; we made that petty GTI look quick..
RE: Clutch :( - MissTap_GTI6 - 20-06-2012 this is true.. i had to slow down; we made that petty GTI look quick.. ![]() Shut up, douche... RE: Clutch :( - strictly_perv - 20-06-2012 Both of yours are slow....
RE: Clutch :( - ginge191 - 20-06-2012 BUT we can go faster than 60mph moral of the story is, get a new gaerbox and help me build my engine as well. thanks. bye.
Clutch :( - MissTap_GTI6 - 20-06-2012 Somehow I still feel like I am losing this battle... To dervs... |
