Rollerbearing turbos - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Rollerbearing turbos (/showthread.php?tid=4036) |
Rollerbearing turbos - Dicky - 09-06-2012 Ok so I have a question, some of you may think its stupid but I'm quite clueless with what turbos will work Would a rollerbearing turbo work well on a Dtub? If not could you explain why please still learning here Re: Rollerbearing turbos - mark_airey - 09-06-2012 Would work fine as long as you got one thats a sensible size, its just a newer design and as a result would be a much better plan, only more expensive................. Look at the Garrett GT series Re: Rollerbearing turbos - Dicky - 09-06-2012 mark_airey Wrote:Would work fine as long as you got one thats a sensible size, its just a newer design and as a result would be a much better plan, only more expensive.................If only my autodata told me what cars have what turbos. Had to take an isuzu trooper to have a service at isuzu the otherday and it sounded the dogs nuts aswell has had amazing power delivery with its rollerbearing turbo Re: Rollerbearing turbos - Ruan - 10-06-2012 Ball bearing turbos tend not to last as long as journal bearing turbos... They're actually stronger and will put up with more abuse, but will actually break faster... They're much more finnicky about oil, you have to have oil restrictors, or you blow the seals out the bearings and in all honesty, don't make that much difference... Put it this way, I've got a journal bearing turbo at the moment, probably a 200hp capable turbo, and it spools as fast as a GT15 and quicker than a T2... Don't waste your money, just as good journal bearing turbos out there for a Diesel application. Re: Rollerbearing turbos - Dicky - 10-06-2012 Ruan Wrote:Ball bearing turbos tend not to last as long as journal bearing turbos... They're actually stronger and will put up with more abuse, but will actually break faster... They're much more finnicky about oil, you have to have oil restrictors, or you blow the seals out the bearings and in all honesty, don't make that much difference...Thanks for clearing that up Re: Rollerbearing turbos - Dum-Dum - 11-06-2012 mark_airey Wrote:Would work fine as long as you got one thats a sensible size, its just a newer design and as a result would be a much better plan, only more expensive................. I thought the GT series used journal bearings. The GT15 certainly does. Re: Rollerbearing turbos - con67 - 11-06-2012 bb turbos work great on petrols because when at cruise they dont really boost but in a diesel on the mway your making more than petrol boost, the journal is much stronger. Stick with journal.... Re: Rollerbearing turbos - Ruan - 11-06-2012 Dum-Dum Wrote:mark_airey Wrote:Would work fine as long as you got one thats a sensible size, its just a newer design and as a result would be a much better plan, only more expensive................. GTxxxxR do use ball bearings... Anything without an R on the end doesn't... |
