306 HDI Ignition Switch Problems - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 306 HDI Ignition Switch Problems (/showthread.php?tid=38074) |
306 HDI Ignition Switch Problems - steve1001 - 23-12-2021 Hi I'm back! Took the 306 for an MOT today. They gave it back to me with a busted ignition switch tumbler! When I insert the key and turn the key, I meet resistance and can't turn the key enough to release the steering lock. After 10 or so attempts I can finally release the steering lock and start the engine, but it is extremely hit or miss. Has anyone had first hand experience of this problem? I assume it is the tumbler at fault. But could it be something else? Can I simply get a tumbler from another 306 and fit it in this 306? Or is there some coded stuff to prevent that. I don't mind having a key for the central locking and another key for the ignition. I have a spare 306 I am using for parts, so I can rob the key and bits off of that one if required. Thanks Steve RE: 306 HDI Ignition Switch Problems - steve1001 - 26-12-2021 I managed to sort it out. I fitted the ignition switch barrel assembly from the spare donor 306 I have. I removed the circuit board and little black transponder chip from my existing key, and fitted those into the key that fits the donor barrel. A very small plastic lug had broken on the plastic electrical switch housing on the barrel assembly. I think the broken plastic lug was fouling the electrical switch mechanism and preventing it from turning properly. I removed the broken lug and the faulty barrel appears to work well again. I can't fathom out what the plastic lug does. It seems to cushion or locate the steering lock bar or something. I will keep the old barrel as a spare! Thanks for looking. RE: 306 HDI Ignition Switch Problems - Mighty306 - 28-12-2021 I'd give cleaning & lubricating the barrel first n then consider replacing it if that doesn't help. Replacements are available, incl on eBay but I've no idea if they're anyy good..https://www.ebay.co.uk/sch/i.html?_nkw=peugeot+306+ignotion+switch&_trksid=p2322090.m4084.l1313 I had a similar issue but often couldn't remove the key. A good aquurt with some electrical contact cleaner & lubricant seemed to sort it out. RE: 306 HDI Ignition Switch Problems - steve1001 - 04-01-2022 (28-12-2021, 09:01 AM)Mighty306 Wrote: I'd give cleaning & lubricating the barrel first n then consider replacing it if that doesn't help. Replacements are available, incl on eBay but I've no idea if they're anyy good..https://www.ebay.co.uk/sch/i.html?_nkw=peugeot+306+ignotion+switch&_trksid=p2322090.m4084.l1313 I oiled the key barrel, but that did not sort it out. As I say, the broken plastic tab seemed to be the cause of my problem. Steve |
