No hot air - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: No hot air (/showthread.php?tid=37685) |
No hot air - ShaneRotty - 07-11-2020 Hi all. I'm hoping this is not what I think it is as I know how big the job will be but I have been struggling to get heat though my vents. There is a very slight heat but not much. I have tried bleeding and I can't get it sorted. There is no leaks from what i can see on both footwells. I have tried flushing and there is water passing both ways. Any help and knowledge would be greatly appreciated [emoji120] Sent from my SM-G970F using Tapatalk RE: No hot air - Mighty306 - 07-11-2020 If the flow & return from the heater core are hot (check from within engine bay) & you've got no coolant leaking inside the car then I'd say the core is fine (not blocked). If you're using a 50:50 mix of glycol & water then even with a slight leak I think you'd smell it in the car. I know that from experience. No hot air - ShaneRotty - 08-11-2020 Flow and return are both hot(flow hotter than return) no leak from inside. Tried bleeding it to death to no avail[emoji55] Sent from my SM-G970F using Tapatalk RE: No hot air - Mighty306 - 09-11-2020 If you're using some sort of header tank to bleed the system you shouldn't have any problem filling it without air locks. I wonder if your issue is with the heater controls themselves. |
