My mystery GTi6 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: My mystery GTi6 (/showthread.php?tid=37682) |
My mystery GTi6 - Black306 - 27-10-2020 Hi all I am wondering if anyone might have the skills to help me at all with my mystery 306 GTi6. - So the V5C doesn't even have a model, it simply says it's a Peugeot. - The V5C and HPI also shows as being imported and a manufacturer date of 2000, but the helpful guys on the GTi6 forum say its a mid 1999 as it looks like a phase 3 apart from the unpainted side strips and orange dials (so likely build just before the formal release of the Phase 3). So the DVLA have the wrong date potentially on the V5C, but the T registration they assigned it in 2001 when imported, sounds right. Not sure why they'd say it was a 2000MY then assign it a 1999 plate! - Finally, I spoke to Peugeot head office and none of their systems return results for the cars VIN (VF37CRFSW32707086). I was wondering if anyone here can either decode the build date from the below suspension mount sticker, or find anything from the VIN? Thanks for reading and any help greatly appreciated. ![]()
RE: My mystery GTi6 - welshpug - 27-10-2020 your RP number is 8163, 16 March 1999. RE: My mystery GTi6 - Mighty306 - 27-10-2020 Build code 8163 is 16th March 1999. I have no idea why Peugeot don't recognise the VIN. May be worth trying somewhere else to see if Peugeot just keyed it in incorrectly? The first half of it certainly looks fine (VF37CRFS) so if there's any issue with the number it's with the W3270.... bit. RE: My mystery GTi6 - Black306 - 27-10-2020 Legends, thank you. The VIN is correct on the V5C and matches both rear/front screen etchings and the tag under the bonnet. I tried it on the Peugeot website and it rejected it. Speaking to Peugeot today, who definitely keyed it correct, having also escalated to their manager, said it's perhaps because the systems typically only go back 15 years they thought. So they have no idea how to find out any details about the car. So as things stand there is nothing that states my car is a GTi other than the first bit of the VIN I believe is correct for a GTi! In short I wanted something official to state it is a GTi and ideally find out where it was first sold (as it's imported from somewhere, but I don't know where). If anyone can help, I'll have to owe then a drink or something small for their car
RE: My mystery GTi6 - Eeyore - 27-10-2020 looks great either way!
RE: My mystery GTi6 - Mighty306 - 27-10-2020 (27-10-2020, 06:43 PM)Mighty306 Wrote: Build code 8163 is 16th March 1999. I have no idea why Peugeot don't recognise the VIN. May be worth trying somewhere else to see if Peugeot just keyed it in incorrectly? The first half of it certainly looks fine (VF37CRFS) so if there's any issue with the number it's with the W3270.... bit. Hehe, Welshpug beat me to it! RE: My mystery GTi6 - Mighty306 - 28-10-2020 (27-10-2020, 07:25 PM)Black306 Wrote: Peugeot ......said it's perhaps because the systems typically only go back 15 years... So they have no idea how to find out any details about the car. It's really odd that Peugeot are saying their records only go back 15 years. The parts department of a Peugeot dealership should be able to pull up the details of your car today from Servicebox using your VIN. My local one (closed last year) were able to pull up my vehicle details when it was over 20 years old. There is a tab that will show all of the vehicle details & trim it came with from the factory. As for the VIN, you are right in saying that it confirms your chassis left the factory with an RFS (XU10J4RS, GTI-6) engine in it. i.e., it is a GIT-6. Whether it still has the same engine it left the factory with is another matter & you would need Peugeot to confirm the original engine number for you. (I've got a downloaded version of Servicebox but it doesn't allow me to search by VIN. RE: My mystery GTi6 - cully - 29-10-2020 servicebox pulls up the vin no problems ![]() the rpo number 08163 it works out to "16 March 1999" build date and DVLA first reg date is 5 feb 2001 there is something strange about your car says warranty started 1990 it is fitted with a rear brake load compensator so defo a ph 2 Vehicle characteristics Vehicle family 306 RESTYL AS/RP N° 08163 81 2 0353 Warranty Start Date 01/01/1990 Engine serial number 10 HKH8 3002048 BER e2*93/81*0152*02 General information PRODUCT TYPE CAR COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT VEHICLE FAMILY 306 RESTYL SILHOUETTE 3 DOOR SALOON TRIM LEVEL SPORT 2 ENGINE INJECTION XU10J4RS TRANSMISSION BVM6 PAINT TYPE NON-METALLIC PAINT INTERIOR TRIM TYPE ALCANTARA "C7" UPHOLSTERY COLOUR "FY" GEARBOX (CHARACTERISTICS) BE3/6 ENGINE (TYPE) XU/XUD OTHER BADGE, " MISC. " WITHOUT FULLER BADGE BADGE GTI 6 Vehicle characteristics TRIM LEVEL SPORT 2 PAINT TYPE NON-METALLIC PAINT INTERIOR TRIM TYPE ALCANTARA "C7" UPHOLSTERY COLOUR "FY" GEARBOX (CHARACTERISTICS) BE3/6 STEERING UNVARIABLE POWER STEERING SPEEDOMETER DRIVE TACHO TORQUE 22X19 Fuel supply-Engine ENGINE INJECTION XU10J4RS FUEL FILLER CAP FUEL CAP WITHOUT LOCK DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+ EMISSIONS STANDARD (ENGINE) UPPER ENGINE EMISSION CONTROL EEC 95 L3/W3 PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER ENGINE (TYPE) XU/XUD CATALYTIC CONVERTER 3 PARTS CATALYST OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE ENGINE TEMP. NOZZLE ENGINE WATER TEMPERATURE BOX CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF POWER VARIATION (ENGINE) STANDARD POWER REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE RHEOSTAT RHEOSTAT VEHICLE TECHNICAL DEPOLLUTION L3 VEHICLE TECHNICAL DEPOLLUTION FAN 2 FANS , 2 RATES FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI Gearbox Transmission TRANSMISSION BVM6 GEARBOX (CHARACTERISTICS) BE3/6 FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 77 SPEEDOMETER DRIVE TACHO TORQUE 22X19 WHEEL STYLE ALLOY WHEEL CYCLONE CLUTCH CABLE CLUTCH TAKING UP OF PLAY AIR CHAMBER WITHOUT INNER TUBE GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING DIFFERENTIAL (GEARBOX) SUPERIOR GEARBOX DIFF TYRE (SIZE, TYPE) 195X55X15 V TYRES WHEELS FITTED 6" RIM ROAD WHEELS WHEEL (TYPE) ALLOY WHEELS GEARBOX TYPE BE3R MANUAL GEARBOX Suspension-Steering-Brakes ABS WITH ABS BRAKES REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 24 ANTI-THEFT DEVICE STANDARD ANTI-THEFT STEERING UNVARIABLE POWER STEERING FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21 TRACTION CONTROL WITHOUT ANTISLIPPING SERVICE BRAKE WITH COMPENSATOR SLAVE BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS SUSPENSION IMPROVED SUSPENSION BRAKE ASSOCIATED VARIANT ADDITIONAL ABS5 BOSCH Body fittings TOWBAR WITHOUT TOWBAR HORNS HORNS-HARMONY AERIAL SHORT ROOF AERIAL FUEL FILLER CAP FUEL CAP WITHOUT LOCK WIPER ARM FRONT BLADE WITH DEFLECTOR HOOD WITHOUT HOOD REAR SPOILER ASSEMBLY WITH REAR SPOILER SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=40 + SIDE SILL WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING HARD TOP WITHOUT HARD-TOP EXHAUST TAILPIPE TRIM WITH EXHAUST OUTLET EMBELLISHER ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR REAR SCREEN WIPER REAR SCREEN WIPER HEADLAMP WIPER W/O HEADLAMP WIPER FRONT PANEL BLANK BUMPER GRILLE NOT CLOSED BUMPER FULL BODY COLOUR SPORT UP TO MOD2000 LUGGAGE RACK WITHOUT ROOF BARS FRONT FOGLAMP FRONT FOG LIGHTS SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL SPARE WHEEL STEEL WHEEL + STANDARD TYRE EXTERIOR ACCESSORIES HANDLE+MIRROR BODY COL/SMOOTH NEUTR RR QUART PANEL SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER REAR SCREEN WASH REAR SCREEN WASH SUN ROOF FIXED ROOF HOOD COLOUR WITHOUT HOOD REAR WINDOW (TYPE) REAR GLASS HEATED GLASS (APPEARANCE) TINTED REAR QUARTER WINDOW (TYPE) PIVOTING REAR QTR GLASS Interior fittings INTERIOR TRIM TYPE ALCANTARA "C7" SIDE ARMREST (TYPE) LATERAL ARMREST FOAM FR + MOULDED RR ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD REAR HEAD RESTRAINT JOINTED REAR HEADREST FRONT HEAD RESTRAINT JOINTED FRONT HEADREST REAR SEAT SEPARATE FOLD BACK BENCH SEAT REAR SEAT ARMREST WITHOUT REAR ARMREST LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP LUGGAGE COVER WITH LUGGAGE COVER REAR SEATBELT RR RETRACT BELT+STATIC LAP FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES SPEED GRADUATIONS GRADUATION MPH GRAB HANDLES FR + RR HANDLES WITH HOOKS TACHOMETER REV COUNTER WITH NEEDLE CONSOLE LONG CONSOLE WITH AIR DUCT DRIVING POSITION RIGHT HAND DRIVE LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH DASHBOARD EQUIPMENT THERMOSLEEVED DASHBOARD + CREADEC PANEL MISC. INT. LAMPS MAP READING LAMP INSTRUMENT PANEL (CHARACTERISTICS) 5 DIALS WITH LUMINOUS NEEDLES TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING LOUDSPEAKER 4 SPEAKERS (2 COAX/FT DOORS+2 BICONICAL/RR SHELF) RADIO CONTROLS REMOTE RADIO CONTROL SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR DRIVER SEAT ADJUSTMENT INCLIN DRIVERS SEAT SQUAB FIXED LAT+LUMBAR BEARING FRONT PASSENGER SEAT ADJUSTMENT INCLIN PASSENG SEAT SQUAB FIXED LAT+LUMBAR BEARING ROOF CONSOLE LONG ROOF CONSOLE CHOKE CONTROL WITHOUT CHOKE FLAP CONTROL EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR COMPACT DISC COMPACT-DISC PRE-EQUIPMENT REAR WINDOW LIFT WITHOUT REAR GLASS LIFT DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER CLOCK NUMERIC CLOCK COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING OIL GAUGE OIL TEMP + LEVEL INDICATOR HEATING ELEMENT NON HEATED SEAT FRONT LATERAL AIRBAG LATERAL AIR BAG PASSENGER AIRBAG PASSENGER AIRBAG EQUIPMENT PACK W/O EQUIPMENT PACK AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT FRONT SEAT GUARD WITHOUT SEPARATION GRILLE RADIO RECEIVER LEVEL 4 RADIO RECEIVER REFRIGERATION REGULAR AIR CONDITIONNING CRUISE CONTROL WITHOUT SPEED CONTROL DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ RHEOSTAT RHEOSTAT CARPET COVER W/O CARPETMAT DRIVER AIRBAG DRIVERS AIR BAG CARPET DILOURS CARPET F330 WEAR INDICATOR WITH BRAKE WEAR WARNING LIGHT INTERIOR PROTECTION W/O PROTECTING NET SWITCH ELECTRONIC ANTI-THEFT KEY COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING TRIM ADAPTATION LEATHER CUSHION AND LEATHER BUTT LOCKING CONTROL CENTRAL DEAD LOCKING REAR WINDOW (TYPE) REAR GLASS HEATED REAR QUARTER WINDOW (TYPE) PIVOTING REAR QTR GLASS STEERING WHEEL SPORT LEATHER STEERING WHEEL 3 BRANCHES STORAGE SPACE LOCKS LOCKING GLOVEBOX FAN 2 FANS , 2 RATES Electrical ALTERNATOR ALTERNATOR 90 AMP HORNS HORNS-HARMONY BATTERY BATTERY L2 300 STARTER MOTOR STARTER MOTOR CL 3 LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT MISC. INT. LAMPS MAP READING LAMP COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP FRONT FOGLAMP FRONT FOG LIGHTS HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT SPECIAL HEADLAMP (DOUBLE OPTIC) DOUBLE OPTIC LAMPS Component manufacturers BRAKE ASSOCIATED VARIANT ADDITIONAL ABS5 BOSCH INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI Miscellaneous SPECIAL SPECIFICATION STANDARD ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE DRIVING POSITION RIGHT HAND DRIVE SIDE IMPACTS DOOR WITHOUT REINFORCEMENT SET OF KEYS 2 IR REMOTE CONTROL KEYS + 1 UNIQUE MAIN KEY DOOR SEAL SEAL DIRT EXCLUDER SURFACE CONDITIONS GOOD TERRAIN EXTERIOR ACCESSORIES HANDLE+MIRROR BODY COL/SMOOTH NEUTR RR QUART PANEL SPEED MONITORING WITHOUT SPEED CHECK SLAVE CONTROL UNIT 30 FUSES BOX EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE RE: My mystery GTi6 - Black306 - 29-10-2020 This is amazing, thank you so much; have messaged you about the drink/part I owe you as a thanks. Just need to try and info out where it was first sold as it was imported apparently. Assume somewhere like Peugeot Dublin. If anyone can find out where it was first sold or any of its owners, I'll owe you a drink or small part ![]() Really strange about the warranty starting in 1990. Also, you say its a Phase 2 but they have put more Phase 3 stuff on it from what I can see, even the spec sheet references the 2000 bumpers for example. Huge thanks again. RE: My mystery GTi6 - Mighty306 - 30-10-2020 Nice work Paul. Can I ask what version of Servicebox you're using? Are you paying for access to it? Cheers, James RE: My mystery GTi6 - welshpug - 30-10-2020 the speedo is in MPH so I don't think it would have been anywhere but the UK, everywhere else RHD use KMH I'm sure, so Ireland, Japan, Australia. I would imagine much like Carl Chambers's rallye it just sat in a storage field somewhere for a while before being registered. RE: My mystery GTi6 - cully - 30-10-2020 (30-10-2020, 06:09 PM)Mighty306 Wrote: Nice work Paul. Can I ask what version of Servicebox you're using? Are you paying for access to it? Cheers, James service box online i dont pay for it ![]() http://public.servicebox.peugeot.com/pages/index.jsp RE: My mystery GTi6 - ekjdm14 - 03-11-2020 The warranty starting 1990 is something I've seen before with our cars, TBH i just thought it was a glitch that all warranties showed that date, anyone ever seen a correct/feasible warranty start date on Servicebox? (perhaps that bit only works on vehicles under 15 years?) Definitely looks a clean example, nice find and love the EXY paint one of my faves. So on the V5c it says previously registered abroad or suchlike? Strange they have the Mfr. date as 2000, perhaps the T-plate was/is a private one rather than age related? I wonder if Isle of Man/Jersey/Guernsey would count as abroad to the DVLA since they have their own plates & presumably IoM at least use miles per hour... RE: My mystery GTi6 - welshpug - 03-11-2020 my 205 showed the same on servicebox for the warranty, even though its a 1989 car |
