turbo oil - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: turbo oil (/showthread.php?tid=37506) |
turbo oil - pug306driver - 12-02-2020 It seems the turbo has been passing some oil, ever since i have had it probably, but it always was good between oil changes need only some oil may be once or twice between changes........and no smoke from the exhaust noticed..... but there is a small river of oil seen entering the inlet manifold after about 20 seconds at 2k revs, so not good. Might there be a kit for the turbo bearing? RE: turbo oil - Martin306 - 13-02-2020 You would just buy a new turbo core if it came to it you can't change the bearing without sending it off for a balance - which is cost you could just spend on a rebuilt core. |
