Alpine - Apple USB leads - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Alpine - Apple USB leads (/showthread.php?tid=3724) |
Alpine - Apple USB leads - cwspellowe - 26-05-2012 Hi fellas, anyone any experience with the IDA-X range of Alpine headunits? Trouble i'm having is connecting my 3gs to my X100. I bought the HU second hand and it didn't have the USB lead. The KCU-422i is for the "full speed" interface for older i-whatevers, and from some extensive reading i've found that the KCU-440i lead will do the trick, but that's no longer available apart from a Chinese seller on eBay. Does anyone know for definite if the KCU-445i will work in the same way? It's for the newer head units but would appear to be basically the same thing. Alpine - Apple USB leads - Parksy87 - 26-05-2012 I could be wrong but just try a standard ipod usb lead, my kenwood said it needed a kenwood usb lead but the standard ones work fine in both my kenwood and the mrs sony Re: Alpine - Apple USB leads - cwspellowe - 26-05-2012 Nah the standard lead doesn't work, the pins are wired differently. A standard USB does sometimes work with Alpine but not all features, or tries to put it into airplane mode. Just took the plunge with a KCU-445i. I know the 440i works with the CDA-105 which in turn works with the IDA-X100, so if the 445i is listed as compatible with the CDA-105, an educated guess says it will also work with the IDA-X100. Here's hoping. £30 for a f*cking lead. |
