Alternator - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Alternator (/showthread.php?tid=36784) |
Alternator - MY95 - 28-04-2018 Hi guys, Need a new alternator for the HDI. Does anyone know the correct part number and amp required as there are various ones on servicebox? Seems to be 90, 120 and 150. Is it easy enough to do the 307 clutched alternator swap? Cheers, Matthew. RE: Alternator - Frosty - 29-04-2018 I had a look at what's on my car and i'm pretty certain this is the one i've got https://www.ebay.co.uk/itm/Peugeot-307-2-0-Diesel-Alternator-With-Ac-9616324880-2001-2008/263415878668?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 The one on my car is a 150 amp one and i haven't had any issues with it. As i said when i was messaging you all you need to do to fit this one is swap the electrical connector bit over on the back of it as the 307 one has a plug for the signal wire which is easy to do any way. Other than that it just bolts on in the exact same way. RE: Alternator - MY95 - 30-04-2018 Spot on, cheers Frosty! Found a reconditioned Genuine Bosch for £65 delivered so have just ordered that Inboxed you before I saw this haha. |
