Am I being an idiot - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Am I being an idiot (/showthread.php?tid=36694) |
Am I being an idiot - Martin306 - 21-03-2018 Lucas pump, non turbo I've been studying some diagrams, so am I right in thinking, the throttle arm travel affects the governor spring pretension hence the max rpm? This would also explain why the stop screw had a stupid security cap on it and why it's a fine thread? I've upped my max fuel already but if you've been following my thread you'll have heard it's still making power at 6000rpm... I know I'm fine at 6k if I can limit it and that screw is the one that limits it? Cheers for any guidance in advance. RE: Am I being an idiot - Piggy - 21-03-2018 8k rpm ftw RE: Am I being an idiot - Martin306 - 21-03-2018 (21-03-2018, 08:32 PM)Piggy Wrote: 8k rpm ftw You know what, I don't think the pistons and rods are even that much heavier than the petrol GTi pistons and rods, it probably would. dat 23:1 compression doe |
