oil problem - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: oil problem (/showthread.php?tid=36635) |
oil problem - pug_345 - 16-02-2018 I think i know the answer to this but here goes i have a 1998 dturbo with lucas pump first starts runs fine for a few mins then its starts jumping and smoking till ive drove it for a few mins thought poss glow plugs but today i needed to replace the pipe from the intercooler to the pump and as ive pulled it off oil poured out there is 2 things in my mind. 1 is turbo 2 is that oil has built up over time due to how the pipe sits any other suggestions RE: oil problem - Dave - 21-02-2018 Take the intercooler pipe off and while watching it, give the engine a high idle (4K etc) and see how much oil is pushed out the intercooler line. Some is expected (eg there will be a little build up but shouldn't be constant), best to post a video of this. The jumping will probably be when your glow plug relay shuts off, your engines not warmed up enough. RE: oil problem - pug_345 - 24-02-2018 (21-02-2018, 10:33 PM)Dave Wrote: Take the intercooler pipe off and while watching it, give the engine a high idle (4K etc) and see how much oil is pushed out the intercooler line. Some is expected (eg there will be a little build up but shouldn't be constant), best to post a video of this. Thanks is the glow plug relay under the steering wheel or under bonnet RE: oil problem - carlukepeugeot - 27-02-2018 (24-02-2018, 10:23 AM)pug_345 Wrote:(21-02-2018, 10:33 PM)Dave Wrote: Take the intercooler pipe off and while watching it, give the engine a high idle (4K etc) and see how much oil is pushed out the intercooler line. Some is expected (eg there will be a little build up but shouldn't be constant), best to post a video of this. Glow plug relay is under the bonnet. It's quite a large beasty, on the passenger side bolted to the inner wing area adjacent to the battery. Think the glow plugs stay on for 3 minutes . That roughly how long it takes before it starts farting an banging? Does it start up really cleanly or a bit rough ? RE: oil problem - pug_345 - 27-02-2018 (27-02-2018, 07:16 PM)carlukepeugeot Wrote:Starts cleanly then as u say 2-3 mins then it starts(24-02-2018, 10:23 AM)pug_345 Wrote:(21-02-2018, 10:33 PM)Dave Wrote: Take the intercooler pipe off and while watching it, give the engine a high idle (4K etc) and see how much oil is pushed out the intercooler line. Some is expected (eg there will be a little build up but shouldn't be constant), best to post a video of this. |
