1.6 THP ???? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: 1.6 THP ???? (/showthread.php?tid=36501) |
1.6 THP ???? - -ER- - 12-12-2017 Hello guys, does anyone did try to swap 1.6thp engine? or does anyone did research swapping 1.6thp engine especially i wonder gearbox mounting does it fit without any modification or what should i do. thanks RE: 1.6 THP ???? - welshpug - 12-12-2017 its very complex and not that great with reliability, though tunes very well. making it fit shouldnt be too hard as its based on the architecture of the tu engine, they sit very upright, they're cable shift which is easy to make work, driveshafts would be cut and shut. ecu would be the most tricky/expensive part as they are multiplex systems. |
