questions about injectors and references - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: questions about injectors and references (/showthread.php?tid=36445)
questions about injectors and references - pedro_s13 - 10-11-2017
good to all, I spent a while chilling an injecyor that when the car warms up it stops making noise sounds metallic and thought to mount other injectors, some know if carrying injectors 062 can I mount any other reference? 076 for example remove and put? Or would I have to do something? RHZ engine
Enviado desde mi SM-G955F mediante Tapatalk
RE: questions about injectors and references - cully - 10-11-2017
https://www.306oc.co.uk/forum/showthread.php?tid=5399&highlight=injector
reading that post that you put, I infer that I could change mine for about 076 and nothing would happen?
dont know on the 406 they may be coded but unsure
No, in the 406 are not encoded, we go in the pp2000 and delphi does not come out that they are encoded is the same as a 306, thank you very much for the answerWink
