what am i doing wrong - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: what am i doing wrong (/showthread.php?tid=36421) |
what am i doing wrong - alex76 - 03-11-2017 hey guys after changing my break shoes on my 306 i also decided to change the drum and bearings (which i had my local garage press) but when it came to refitting the drum i can only get the hub nut to 30nm on the torque then the drum locks and wont move. please guys can someone help as its driving me nuts
RE: what am i doing wrong - welshpug - 03-11-2017 got the bearing pressed all the way in and the clip fitted? RE: what am i doing wrong - alex76 - 03-11-2017 (03-11-2017, 04:22 PM)welshpug Wrote: got the bearing pressed all the way in and the clip fitted? yeah and checked with old hub and both look the same RE: what am i doing wrong - cully - 03-11-2017 removed the old bearing iner race from the stub shaft? RE: what am i doing wrong - alex76 - 04-11-2017 (03-11-2017, 06:16 PM)cully Wrote: removed the old bearing iner race from the stub shaft? yeap all clear... going to refit the old drum tomorrow see if it still dose the same RE: what am i doing wrong - Uberderv - 04-11-2017 Incorrect brakeshoes? They could be too wide so when you tighten the nut it's pressing against the shoe. Or another possibility is that a worn inner drum face creates an indent where the old shoe would of ran, new shoes have a square edge causing it to be pressed against it when the nut is tightened. RE: what am i doing wrong - Poodle - 04-11-2017 Have you wound the adjuster back? RE: what am i doing wrong - alex76 - 12-11-2017 cheers for the input guys will have another go later |
