LPG Fumigation - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: LPG Fumigation (/showthread.php?tid=3637) |
LPG Fumigation - londondan86 - 22-05-2012 Anyone heard of it? I stumbled across a wiki page yesterday and began reading. The way I understand it is that the injection of LPG (usually propane) into the air intake will help to ensure that all of the diesel in the cylinder burns. This creates better economy, better emissions and more powarrr!! As the engine draws in the air/lpg mixture it enters the compression stroke, this compresses the mixture to just below the propane flashpoint temperature. As the piston returns up the fuel is injected, the fuel ignites instantly which also ignites the propane/air mix for the power stroke. On a well set up diesel engine the efficiency is supposed to be around 75% (according to google), with the propane injection this goes up to 90%. Sound good or just another nitrous. Discuss Re: LPG Fumigation - silverzx - 22-05-2012 Sounds like a lot of ball ache to me! Re: LPG Fumigation - d-jimbo - 22-05-2012 sounds good if u could get it working right, the main downside would have to be cruising around with an explosive gas tank in the car. other than that it does sound similar to nitrous, im assuming that the propane wouldnt auto ignite? Re: LPG Fumigation - Toby - 22-05-2012 Propane pre-ignites at 470 degrees.. I doubt that would be suitable for even a stock XUD engine, let alone a tuned one running higher boost? Maybe it would work on a direct injection set up with a shorter burn time? Re: LPG Fumigation - cully - 22-05-2012 yes ive read about it and have also played with HHO fumigation too look up browns gas i built my own HHO generator and had it running in the car for a while Re: LPG Fumigation - londondan86 - 22-05-2012 d-jimbo Wrote:sounds good if u could get it working right, the main downside would have to be cruising around with an explosive gas tank in the car. other than that it does sound similar to nitrous, im assuming that the propane wouldnt auto ignite? Isn't that what you do with a petrol tank lol! And petrol is a lot more volatile than propane. I don't know at all if it would be suitable for the XUD apparently due to the fact that IDI engines use a swirl pot pre ignition the flame front would ignite the propane too early so wouldn't be as effective. Just found this: http://www.mrsharkey.com/lpg.htm Still might be worth a pikey knock up, I was thinking using a pressure switch that opened up the lpg tank at 10 psi (boost) and closed again off throttle. Its just a case of making sure you don't use too much!!! Re: LPG Fumigation - Dum-Dum - 22-05-2012 I looked into this ages ago and from what i remember i decided that the amount you could inject would be so tiny that it would have very little effect especially if you were running big boost and/or lots of fuel Re: LPG Fumigation - Ruan - 23-05-2012 Remember most of the problem people have is getting air into the engine, Propane needs air to burn, it's just another fuel... That's why Nitrous makes a huge difference - it's an oxygen source and Methanol simply cools down the charge if you've got no oxygen left to burn the charge with. Re: LPG Fumigation - d-jimbo - 24-05-2012 so is anyone actually running nitrous on an xud? or water/meth for that matter? Re: LPG Fumigation - mark_airey - 24-05-2012 d-jimbo Wrote:so is anyone actually running nitrous on an xud? or water/meth for that matter? there are a few people running water meth on here ![]() Re: LPG Fumigation - Ben Jay - 24-05-2012 d-jimbo Wrote:so is anyone actually running nitrous on an xud? or water/meth for that matter? my friend has a nitros system that he was going to stick on his mk3 golf before it blew up! So its just laying around now....might be worth having a look! ah he sold it a couple of weeks ago. how would it work with the extra fuel needed for when the gas was injected? Re: LPG Fumigation - Ruan - 24-05-2012 You don't need to compensate it, it's a diesel... The best way to use Nitrous on a diesel is as an antilag system with a chronic turbo... Re: LPG Fumigation - d-jimbo - 24-05-2012 so any good results with the water/meth then? if using nitrous, surely there would be less need for a chronic turbo? or would the combustion temps get too high to be using that as an 'all over' power enhancer? Re: LPG Fumigation - mechsman - 24-05-2012 If you were to use nitrous to spin a hoofing great turbo, where would the nozzle go and when/how often would you squirt it? Re: LPG Fumigation - d-jimbo - 25-05-2012 u still trying to find a way to make that holset work on a d turd? Re: LPG Fumigation - mechsman - 25-05-2012 Lol! Debating it again now that using nitrous to spool it has been mentioned! Needs a rebuild though as the compressor wheel has damaged blades. So, how big a shot and where to inject it? Re: LPG Fumigation - d-jimbo - 25-05-2012 get a nice tight seal between the nozzle and the sphincter, i recommend some instant gasket and a mikalor clamp. then give a massive squirt every time u think of putting that ridiculous turbo on, until the thought goes away. problem solved! Re: LPG Fumigation - Ben Jay - 25-05-2012 d-jimbo Wrote:get a nice tight seal between the nozzle and the sphincter, i recommend some instant gasket and a mikalor clamp. then give a massive squirt every time u think of putting that ridiculous turbo on, until the thought goes away. problem solved! giggedy Re: LPG Fumigation - Ruan - 25-05-2012 If its that thing you posted up a while ago, you won't spool it, you could be farting nitrous and gas but try as you might, the airflow through an xud9 just isn't going to happen... Re: LPG Fumigation - mechsman - 25-05-2012 d-jimbo Wrote:get a nice tight seal between the nozzle and the sphincter, i recommend some instant gasket and a mikalor clamp. then give a massive squirt every time u think of putting that ridiculous turbo on, until the thought goes away. problem solved! Here's a thought, piss off you f*cktard. Good, problem solved. My (perfectly reasonable) original question about when, where and how much nitrous should be injected in order to spool a really big turbo still stands. Re: LPG Fumigation - d-jimbo - 26-05-2012 ![]() Orite man, chill out. i was only joking, just couldn't help myself. seriously though, if u need some help getting it attached.... Re: LPG Fumigation - Ruan - 27-05-2012 If it's that one you posted a while back.. I promise you, it's not going to happen. Re: LPG Fumigation - mechsman - 27-05-2012 Gah, why can't people answer the question! All I was asking was opinions on how to use nitrous to spool a big turbo as suggested! I didn't have any particular one in mind but using nitrous to help spool it may allow a wider range of turbos than I was originally considering. Re: LPG Fumigation - Ruan - 27-05-2012 That's a silly question and very vague at that... If you just want to reduce lag, fair enough, but you don't seem to realise the difference between lag and boost threshold... Yes you can use LPG to help spool bigger turbos, of course, but in all honesty, if you need a turbo big enough to need LPG to spool it, then either A. You can get a more efficient, modern turbo. or B. If it's modern enough, then your cylinder head will never flow enough without SIGNIFICANT modification... |
