Turbo - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Turbo (/showthread.php?tid=36292) |
Turbo - AmedeoRS - 11-09-2017 Good morning everyone. I would like information on how to change the turbo to my 306. Who can help me? Sorry for my low knowledge of english ![]() ![]() ![]() ![]() RE: Turbo - Mattcheese31 - 11-09-2017 well, if you support the engine underneath, loosen the top engine mount, rock the engine towards you by slowly letting the jack down, you should have enough room down the back of the engine to change it, anything else you need? RE: Turbo - AmedeoRS - 11-09-2017 Thank you. If I just want to modify it? Wastegate? (11-09-2017, 10:16 AM)Mattcheese31 Wrote: well, if you support the engine underneath, loosen the top engine mount, rock the engine towards you by slowly letting the jack down, you should have enough room down the back of the engine to change it, anything else you need? RE: Turbo - Chris_90 - 11-09-2017 Up from under subframe to turn it up. |
