Peugeot 806 with the 1.9TD - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Peugeot 806 with the 1.9TD (/showthread.php?tid=36160) |
Peugeot 806 with the 1.9TD - unclebeast - 24-07-2017 What do you look for when buying one is there cat/egr engine management ecu. are they reliable...XUD9TE? Anyone tuned one? RE: Peugeot 806 with the 1.9TD - Mattcheese31 - 24-07-2017 same engine afaik, will depend on year as to ecu etc, they changed them to HDI same as everything else too after a certain time
RE: Peugeot 806 with the 1.9TD - Dum-Dum - 24-07-2017 I don't know if the XUD9s have an ECU but IIRC they did the XUD11s in them and they didn't do a pure mechanical XUD11 so like the 406 I reckon theres a probability that they had ECUs Kyle Kaye has one (find him on FB as he's a .net member) so ask him. RE: Peugeot 806 with the 1.9TD - r3k1355 - 26-07-2017 Could you not convert to a mechanical pump easy enough? RE: Peugeot 806 with the 1.9TD - welshpug - 26-07-2017 yes. I believe most of them will be the semi ecu controlled things like the 406. pretty standard fare engine wise, much like most XUD's, gearboxes can play up as they are in an 1800 kilo vehicle so get worked hard all the time, suspension running gear etc is all van based so very sturdy, they only tend to rot when damaged, electricals and plastic things can cause problems. RE: Peugeot 806 with the 1.9TD - HDIkyle - 26-07-2017 I am on here aswell Chris ![]() They come front mounted as standard. They are quite underpowered in standard form tbh just a case of swapping the pump and I removed the ecu with a light tune makes a massive difference. You forget its such a heavy car now. They are riedics tight to work on tho and the cable gear selectors can be a pain. The rubber ends have come away on mine and re over 100 to replace the cables Also the bootlids crack along the numberplate section so look out for this. Usually from slamming it they do seem to flex a lot RE: Peugeot 806 with the 1.9TD - unclebeast - 28-07-2017 If you had to recommend an older type mpv diesel load lugger would it be an 806/synergie/ulysee as I have a really good xud9te in my defunct 405 project, but know zilch re the three mpv`s mentioned above. |
