Boost seems to be coming in later?? Any ideas? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Boost seems to be coming in later?? Any ideas? (/showthread.php?tid=35961) |
Boost seems to be coming in later?? Any ideas? - wdoyle2410 - 26-05-2017 Hi all, Had my '96 1.9TD for a while now and lately the boost seems to be coming in later and later. Doesnt seem to make any (noticable) boost until 3000RPM. When i first got the vehicle it seemed to come in much quicker and seemed more powerful also. Does anyone have any ideas of what i can check? It's got a Lucas pump which i HAVEN'T tweaked but i did remove it recently to replace the shaft seal. I dont believe there are any boost leaks, not that i can hear anyway. Thanks in advance, Will. RE: Boost seems to be lagging more?? - welshpug - 26-05-2017 checked the air filter? RE: Boost seems to be lagging more?? - wdoyle2410 - 26-05-2017 I did check it and there were no obvious obstructions. Looked relatively clean. I did order one today that will be here in a week or so anyway. Thanks I might just remove it and go for a Quick run tomorrow to determine if that's it or not. RE: Boost seems to be coming in later?? Any ideas? - bashbarnard - 26-05-2017 check the actuall turbo for play and or damage as well as they are getting on a bit now. RE: Boost seems to be coming in later?? Any ideas? - wdoyle2410 - 26-05-2017 Cheers, will do. What's the easiest way to get the turbo off? From the bottom or the top by taking the inlet manifold off? RE: Boost seems to be coming in later?? Any ideas? - Frosty - 27-05-2017 Just pop the intake pipe off and have the feel of the turbo shaft for play. Maybe easier to pop the engine off the cam belt end engine mount to get better access. RE: Boost seems to be coming in later?? Any ideas? - Ruan - 27-05-2017 Change the fuel filter and if not check tank strainer. RE: Boost seems to be coming in later?? Any ideas? - wdoyle2410 - 27-05-2017 Thanks guys. Will be getting a new fuel filter very shortly. Whilst looking around the engine bay I noticed a black plug that was unplugged from the fuel filter housing. Plugged it in and now the 'water in fuel filter light' stays on. Did drain a little water out it that s stopped it for ten minutes but then came back on. Is this sensor known to be faulty? Hence why it was unplugged. RE: Boost seems to be coming in later?? Any ideas? - Frosty - 28-05-2017 Yeah that can be a common issue on the xuds, i would say when you change the fuel filter drain it all out and unscrew the sensor and give it a bit of a clean and then see is the light stays on after that. RE: Boost seems to be coming in later?? Any ideas? - andywhy - 30-05-2017 Check the intercooler D seal hasn't split or blown out as it can leak from there and be difficult to find. They're usually a few quid from a dealer. I had that issue once before. RE: Boost seems to be coming in later?? Any ideas? - wdoyle2410 - 30-05-2017 Thanks for that, will give it a check. Would an rtv be suitable for that? RE: Boost seems to be coming in later?? Any ideas? - wdoyle2410 - 17-06-2017 Replaced the fuel filter and the intercooler seal which had a split in it. boost now comes in earlier but ive noticed that at times when under boost in 5th the boost will fluxuate up and down, like goes from 12psi to 5 for a brief second then then goes back up, does this a few times before settling out again. any ideas on this? Also its not just the boost gauge thats fluxuating. i can feel a sudden loss of power then sudden increase in power again. very noticable |
