Which clutch for 97 DTurbo - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Which clutch for 97 DTurbo (/showthread.php?tid=35862) |
Which clutch for 97 DTurbo - heyitsroth - 24-04-2017 Need a new clutch for my 97 1.9 DTurbo - any recommendations? I've read that stock Valeo would be a good bet- Amazon and Valeo's website say the model is 801416. Is that a good price? The motor factors give 3000855401 which they say is Valeo, but it's a Sachs part number - are they sharing parts or something? There's also this Valeo classic range, for cars 10 years old or more - anyone have any experience with those? Sounds like its a bit cheaper for less durability, the idea being your car won't last that much longer anyway ![]() Finally are there any parts that I'll need that aren't in the kit? Should the clutch cable be changed while it's out? Thanks! Which clutch for 97 DTurbo - bashbarnard - 25-04-2017 Yeah they clutch looks tight it sayd dt. Just double check some other part numbers it lists as well and you should be fine. Never heard of valeo classic before. Id definitly dondrive shaft seals while the box is out and change the oil for genuine pug stuff. The cluthh cable i would leave if its in good condition if not replace. Sent from my iPhone using Tapatalk RE: Which clutch for 97 DTurbo - Frosty - 25-04-2017 Pretty much what bash has said plus i would change the clutch fork bushes and the shaft seal in the gearbox as well while the box is out. RE: Which clutch for 97 DTurbo - Frosty - 25-04-2017 Also you can get a valeo one from GSF and on most weekends they have at least 50% off so would be around £75 for one https://www.gsfcarparts.com/parts/transmission/clutch/clutch-kit And these are the clutch fork bushes you want to replace http://www.ebay.co.uk/itm/PEUGEOT-CITROEN-BE3-GEARBOX-CLUTCH-RELEASE-BEARING-ARM-BUSHES-217520-217521-/361948287866?hash=item5445cc937a:g:cNcAAOSw~CFY54Yy And the guide tube that i always think is worth replacing http://www.ebay.co.uk/itm/Citroen-Xsara-Picasso-N68-1999-2016-Oem-Clutch-Guide-Tube-Shaft-Seal-/301935497366?hash=item464cc21096:g:JP4AAOSwMsVXjauF RE: Which clutch for 97 DTurbo - heyitsroth - 26-04-2017 Thanks for the replies and the links, much appreciated Regarding the seals, are these the right ones http://www.ebay.co.uk/itm/171696521924? Or on GSF they have "diff seals" right and left? I have gearbox oil, but it's been sat in the garage for about 6 years - it doesn't go off does it? Also, the cambelt was done about 25k ago, but that was also about 11 years ago - does the amount of time mean it should be replaced? Just thought it might be good to have it all done in one go RE: Which clutch for 97 DTurbo - Frosty - 26-04-2017 Yeah they look the right seals, though they can be called diff seals as well. I dont think the oil can go off to be honest. As for the cam belt you will want to get that changed due to the length of time that it hasn't be changed for. Think they are due every 5 or 6 years. RE: Which clutch for 97 DTurbo - heyitsroth - 26-04-2017 Yeh that's the yearly interval people seem to give for the timing belt. I'll make a separate thread on here to ask though, just to be sure, since I can't find anything in the manual about it. Sorry to keep asking questions, but I just want to make sure I buy the right stuff: am I right in thinking the two seals that have been mentioned in this thread are marked 9 and 10 on this diagram? ![]() Or is one of them marked 6 on this diagram? ![]() RE: Which clutch for 97 DTurbo - bashbarnard - 26-04-2017 9 and 10 on the first one mate |
