Bosch pump rebuild! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=39) +--- Thread: Bosch pump rebuild! (/showthread.php?tid=35841) |
Bosch pump rebuild! - Paul_13 - 17-04-2017 Had a 9mm bosch pump spare and thought I'd rebuild it. Have it a good degreasing yesterday and look at stripping it during the week. I'll post photos up shortly RE: Bosch pump rebuild! - zx_volcane - 18-04-2017 good idea paul, get as many photos as you can and do a guide if you want? got yourself a triangular socket for the odd bolts, or going to hack up an old 13mm socket? jus remember cleanliness is next to boschliness also, use of vaseline for holding components in place during assembly (pro pg tipz) swearing is optional, forcing components isn't - some will break under duress. RE: Bosch pump rebuild! - Dave - 18-04-2017 The old VE rebuild, yes do not force anything! Bosch pump rebuild! - bashbarnard - 18-04-2017 Ive got a video somewhere of a strip down if thats anyhelp. Sent from my iPhone using Tapatalk RE: Bosch pump rebuild! - Frosty - 19-04-2017 Great idea. Be good to see a proper guide done for it. I've just sorted the pump out on my 205. There not that bad to do i would say now once you've had a couple apart. RE: Bosch pump rebuild! - yes306 - 15-05-2017 How's the build going? RE: Bosch pump rebuild! - Paul_13 - 15-05-2017 Haven't got round to it yet |
