Peugeot expert 1.9 dw8 help - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: Peugeot expert 1.9 dw8 help (/showthread.php?tid=35782) |
Peugeot expert 1.9 dw8 help - Chris_90 - 03-04-2017 A mate of mine has got a 54 plate expert it's a 1.9 dw8 engine, the issue is i has a intermittent no glow plug warning light, meaning it won't start. I've tried a straight 12v to plugs still won't fire, the garage he took it to first told him they changed the crank sensor? I didn't think they had a crank sensor? Correct me if I'm wrong? So any one have any idea what would be causing it because when the warning light does work it starts straight away with out issue. RE: Peugeot expert 1.9 dw8 help - welshpug - 03-04-2017 could be immobiliser issue. RE: Peugeot expert 1.9 dw8 help - Danny Wideboy - 04-04-2017 As above, should barely need glow plugs on a DI this time of year. RE: Peugeot expert 1.9 dw8 help - welshpug - 05-04-2017 its not Di. RE: Peugeot expert 1.9 dw8 help - Danny Wideboy - 05-04-2017 Then I have learned something else today. RE: Peugeot expert 1.9 dw8 help - bashbarnard - 05-04-2017 (05-04-2017, 06:02 PM)Danny Wideboy Wrote: Then I have learned something else today. Yeah they are idi last of the idis. funny sort of mix the mounts dont quite line up for a bosch pump as they share the block castings with the dw10. But its easy enough to fit a fully mechanical bosch on them |
