DT Air box fitment - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: DT Air box fitment (/showthread.php?tid=35722) |
DT Air box fitment - Midnightclub - 16-03-2017 So it appears to be getting more and more difficult to get a standard airbox for the GTi6 or getting one that hasn't rusted away. The ones for the 1.9 D look similar but not identical, but are made out of plastic so no rust issues. I believe they do take the same sized filter element as a GTi though. From pictures alone it looks like it should fit with a 90 degree silicon or something for the cold air intake side, OEM TB intake hose looks like it should just fit the filtered air side Thoughts? http://www.ebay.co.uk/itm/Genuine-Peugeot-306-Partner-Citroen-1-9-Diesel-Air-Filter-Housing-Box-1427H2-/271938870642?hash=item3f50d1dd72:g:WucAAOSwgQ9VsjND RE: DT Air box fitment - welshpug - 16-03-2017 all the dt filter boxes ive seen have been steel and just as rusty RE: DT Air box fitment - Midnightclub - 16-03-2017 One in the link above is plastic, all the other brand new ones ive seen are plastic too DT Air box fitment - Sambarker - 16-03-2017 Are they not plastic with a metal base? Sent from my iPhone using Tapatalk RE: DT Air box fitment - Midnightclub - 16-03-2017 Possibly, but I can't tell from the picture and it doesn't state. Either way it's a brand new Peugeot item, I've seen them as cheap as £35-38 posted. Currently a rusty GTI6 airbox on ebay is £50 collected albeit it's the only one on there RE: DT Air box fitment - bashbarnard - 16-03-2017 The one on lus that i pulled off a scrapper we had. Is all plastic. including bottom RE: DT Air box fitment - KevinTW - 18-03-2017 (16-03-2017, 03:23 PM)Midnightclub Wrote: So it appears to be getting more and more difficult to get a standard airbox for the GTi6 or getting one that hasn't rusted away. RE: DT Air box fitment - Midnightclub - 18-03-2017 Np, let me know how you get on if you get one, will probably get one myself to try soon RE: DT Air box fitment - darrenjlobb - 21-03-2017 Ph1 are all metal , Ph2 are plastic... From what I seen anyways. RE: DT Air box fitment - Midnightclub - 21-03-2017 Assuming they don't make the PH1 boxes any more/they're out of stock now? Don't suppose anyone knows the inlet size for the DT box if they have one lying around? Believe the '6 intake piping is 76mm |
