Newbie that needs a code reader - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: Newbies (https://www.306oc.co.uk/forum/forumdisplay.php?fid=24) +--- Thread: Newbie that needs a code reader (/showthread.php?tid=35709) |
Newbie that needs a code reader - Greybrother - 13-03-2017 Hi All, Been lurking for a while trying to find info. I have (since new) a 306 HDI Meridian estate, Nov 2000. Could anyone point me in the direction of a code reader? Need to reset to turn engine management light off, I know why it came on and that has been rectified. All the code readers I come across seem to be for 2014 onwards. Have tried local garage services with out any luck. Thanks RE: Newbie that needs a code reader - Eeyore - 13-03-2017 Just one of the eBay 5 quid blue tooth ones with the torque mobile app will do the job
RE: Newbie that needs a code reader - Nexus - 13-03-2017 I use a Maxiscan MS300, cost about £12.99 on amazon at the time. Use it on my phase 3 estate as well as an '02 Astra (95% of cars after 1996). Very, very basic but will give you codes and can clear the engine light. RE: Newbie that needs a code reader - Greybrother - 21-03-2017 Many thanks for replies. Bought an MS300, good job they are cheap. Doesn't fit mine, has 16 pins but is a slightly different shape, car has a locating lump (i assume) sticking up stopping the scanner fitting. Guess mine is not OB2 compliant. Anyone got any ideas? It is a Nov 2000 reg car 2ltr deisel. RE: Newbie that needs a code reader - Midnightclub - 21-03-2017 All OBD ports should be identical on the pugs afaik.. the scanner cable should have a little notch for the bit you're on about. If you've got an android phone, just do what eeyore said and get a bluetooth obd scanner and the torque pro app RE: Newbie that needs a code reader - Poodle - 27-03-2017 Just cut the notch in it yourself tbh. Ps welcome along! RE: Newbie that needs a code reader - allye - 27-03-2017 Local garages cant turn off a dash light? Go to better garages!!! |
