405 brakes on a 205 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: 405 brakes on a 205 (/showthread.php?tid=35702) |
405 brakes on a 205 - Doseph - 12-03-2017 Does anyone know if the brakes from my 405 GLX d turbo are a direct fit onto a 205 1.8 diesel Style? RE: 405 brakes on a 205 - Pugmarshall - 12-03-2017 I'm sure you cannot use 405 brakes as the calliper mounts are different, your best bet would be 306 HDI callipers with 266mm discs. RE: 405 brakes on a 205 - welshpug - 12-03-2017 indeed not, radius of the caliper mounting lugs is taller and much lower offset discs. RE: 405 brakes on a 205 - Doseph - 12-03-2017 thanks guys
