acf-50 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: acf-50 (/showthread.php?tid=35693) |
acf-50 - Stef205 - 09-03-2017 Im looking at another alternative to the horrid underseal. I like to keep the 205's under carriage as good as i can. Currently its coated with red oxide and black hammerite which has served me well, 6 years infact. Im not a fan of most underseal paints/sprays mainly as some never dry and alot contain water! Ive come across a product called "acf-50" which appears to be a clear drying liquid. Seems to tackle corrosion aswell as block it unlike unseal. My question is has anyone had any experience with it or similar products? http://www.acf-50.co.uk/ Stef
RE: acf-50 - Jonny81191 - 10-03-2017 Por-15 is the dog's dangles, never heard of acf-50.. RE: acf-50 - wainwrightj - 10-03-2017 "Corrosion Block, the Facts!
I may have this wrong but it sounds like it's a liquid film that doesn't harden? RE: acf-50 - Strikeforce - 10-03-2017 I use acf-50 on my motorbikes during winter and does an amazing job at keeping the salt from turning my bikes brown, its not a one use product though! Majority of bikers who ride during winter use acf-50 then wash it off when the gritters dissapear. I ride regular during winter so i have to re apply the stuff where the rain/puddles washes it away. In short its fantastic stuff but not ideal for a car. RE: acf-50 - Ben_w - 10-03-2017 POR-15 is properly fussy about prep and has been known multiple times to fail and come off in sheets. I wouldn't use it. Underneath of the Rallye, that got baremetalled 2 years ago and then stood for that time......Is just as good as the day I left it. Bilt Hamber zinc primer, with Bilt Hamber epoxy mastic over the top. I topped it off with flat finish 3M stone chip......Ain't nothing touching that. RE: acf-50 - welshpug - 10-03-2017 I'd rather renew the original type of under body surface protection, I agree all that shultz type stuff is bloody horrible. RE: acf-50 - Ruan - 10-03-2017 What did they use from the factory originally?! RE: acf-50 - Rippthrough - 10-03-2017 ACF-50 is good but as said, needs to be washed off and reapplied after a while, it's like a gel version of WD40 in terms of what it does. Dynax UB is what you're looking for I think. RE: acf-50 - Ben_w - 11-03-2017 From the factory, from what I have found getting through my Rallye, the underside was primed, then heavily stone chipped in places. In other places, it just appeared to be painted (boot floor, tunnel etc.....) RE: acf-50 - Matt-Rallye - 11-03-2017 6 years isnt bad for the red oxide and black hammerite! How often do you clean the underside? if you regularly check & clean the underside i would just suggest refreshing what you have already done. |
