Help! 106 not starting - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: Help! 106 not starting (/showthread.php?tid=35444) |
Help! 106 not starting - Matt - 07-01-2017 So my neighbour has a 106, the rocker gasket had gone, so I replaced that for her. But she has a starting problem she wants me to fix, basically she was driving home something went bang and and then the car stopped. When you get in the car, turn the key, all that is heard is a very loud click from engine bay My first thoughts was something internal, belts gone? Starter motor failed? I have no idea where to start RE: Help! 106 not starting - bashbarnard - 07-01-2017 pop the top timing belt cover off. 2 10 mmm bolts. takes around 30 seconds. will check the belts ok right quick if its just clicking could be the starter. get someone to held the key in the start position and give it a tap. may go RE: Help! 106 not starting - Matt - 07-01-2017 Where about are the starters located on these? The loud clicking sound like it's coming from the rear of the engine bay RE: Help! 106 not starting - bashbarnard - 07-01-2017 yeah thats where the starter motor is on them. theyre not to bad to do to be fair. you can reach them and give them a tap with extension bar if you try hard enough. youll need a set of axle stands or some ramps to change it with ease though. not impossible without but advised. RE: Help! 106 not starting - ginge191 - 08-01-2017 I'm around today if you need a hand; can call me if need be What engine is it? RE: Help! 106 not starting - welshpug - 08-01-2017 if it went bang get a spanner on the crank pulley, its probably dead. RE: Help! 106 not starting - cully - 08-01-2017 daughters 206 Tu engined went bang that removed five teeth from the cam belt and mashed many valves removing the top cover didn't reveal much as the belt was still on the pulleys but did still turn over with no compression what's so ever RE: Help! 106 not starting - Matt - 08-01-2017 Right well I'm taking another look at it tomorrow. But I seriously think it naught be dead, the woman's description sounds like belts gone so that will come off |
