Guys, send help, SOS - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Guys, send help, SOS (/showthread.php?tid=35438) |
Guys, send help, SOS - Matt - 06-01-2017 Nah but in seriousness. How many time would you have to start a hdi to kill the battery? I've been working on the car in restricted space, so done a lot of starting turning the car around, turning off. The battery has had no chance to charge it as I've driven it for literally 2mins at a time. Went out to go to town and turned the key, turns engine 3 times and proceeds to go slower and slower! I've been playing with it a lot, it's got an after market alarm/central locking, it had a lot of excess wires and I trimmed those back. But I'm thinking I might have disturbed something? Or caused it to drain the battery somehow? Had no warning lights before this RE: Guys, send help, SOS - zx_volcane - 06-01-2017 sounds like it just needs a decent charge tbh battery won't thankyou for endless starts and no charging though RE: Guys, send help, SOS - Ruan - 06-01-2017 Sounds like old, shagged battery combined with short runs. Replacement battery probably wouldn't go a-miss, but as long as you're careful, it'll probably last a while longer yet, just be aware that the battery is crap and you can't just stop/start it to move it around etc. RE: Guys, send help, SOS - Matt - 06-01-2017 Replacement battery is on its way. Just wondered if there was anything else likely to drain? RE: Guys, send help, SOS - DeeTurbo - 06-01-2017 Seeing as it's got aftermarket bits and wiring mods it might be worth checking for a parasitic drain. RE: Guys, send help, SOS - cully - 07-01-2017 (06-01-2017, 10:34 PM)DeeTurbo Wrote: might be worth checking for a parasitic drain. oh no.......waits for the post How do you do that and my battery has exploded and my meter has melted RE: Guys, send help, SOS - Ruan - 07-01-2017 I just wanted to know what the start current was... So I connected up my meter... There's now only a big pile of molten plastic... RE: Guys, send help, SOS - pug306driver - 07-01-2017 LOL LOL, sorry............... about 200 amps ( probably more as its a diesel and cold ) at first dropping to about 100 amps ish when the engine is spinning, the crank that is..........suprised fuse didn't blow in the dmm?? As a matter of interest I have a small dial amp meter which is placed along side a wire to "measure" amps, will give it a go to see if it still works. RE: Guys, send help, SOS - Matt - 07-01-2017 I charged the battery, stuck it back on and it started first time. Had something I had to do at work today so haven't managed to take much of a look at it yet Guys, send help, SOS - zx_volcane - 07-01-2017 Keep it on trickle charge if you can for s bit? Sent from my iPhone using Tapatalk Pro |
