ECU swap - help - - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: ECU swap - help - (/showthread.php?tid=35357) |
ECU swap - help - - daww - 19-12-2016 Is there a guide to ECU, BSI and Key swapping? Want to get the remap off my old HDI and on my new one before i sell the old one, Cheers!
ECU swap - help - - bashbarnard - 19-12-2016 Swap ecu about 4 10 mm bolts i think, remove centre console two 10 mms under the gear gator and some torx 20s in the ask tray, remove front part of centre console two torx 20s. Bsi is held in with some torx 30s i think little black box at bottom of the dash. Swap key blade into old key job done. Should take no more than 30 mins really nice and easy Sent from my iPhone using Tapatalk RE: ECU swap - help - - daww - 20-12-2016 (19-12-2016, 10:02 PM)bashbarnard Wrote: Swap ecu about 4 10 mm bolts i think, remove centre console two 10 mms under the gear gator and some torx 20s in the ask tray, remove front part of centre console two torx 20s. Bsi is held in with some torx 30s i think little black box at bottom of the dash. Swap key blade into old key job done. Should take no more than 30 mins really nice and easy Cheers man - big help! trying to save myself a bit of money and not have to get the new pug remapped
RE: ECU swap - help - - bashbarnard - 20-12-2016 no worries man always happy to help out where i can i dont the same to my current daily as i didnt want to get it mapped due to the fact i know im replacing the engine anyway RE: ECU swap - help - - daww - 24-12-2016 (20-12-2016, 08:52 PM)bashbarnard Wrote: no worries man always happy to help out where i can i dont the same to my current daily as i didnt want to get it mapped due to the fact i know im replacing the engine anyway yeah makes sence really, have fun swapping engines going about swapping ecu etc on boxing day
