Morette wiring - Printable Version
+--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23)
+--- Thread: Morette wiring (/showthread.php?tid=3526)
Morette wiring - rik1254 - 16-05-2012
Why cant I find a simple guide....either written in some jibberish or the diagram is for the main beam/ side lights.....and I need to know how to wire the dipped beam in.
Anyone have a complete diagram or clear written guide?
Its for P2/3 morettes, coming from H7 to H4....unless H7's can be wired in?
Re: Morette wiring - Daniel306 - 16-05-2012
Would it not be easier to look at and orignal ph2 headlight and copy the way it wire, or get scrap ones like i did and use the loom from them
Re: Morette wiring - rik1254 - 16-05-2012
I thought p2 and p3 lights were the same up to the point if the lenses?
Re: Morette wiring - Eeyore - 17-05-2012
I thought the wiring was exactly the same and you just needed the Phase 3 light stalk to make them work properly? Ive got some morettes which ive never got out the drawer since i got them. Ill have a go at some point!
Re: Morette wiring - Daniel306 - 17-05-2012
Ph2 uses H4 bulbs and ph3 uses H7 so the loom is slightly different
Re: Morette wiring - swampy - 17-05-2012
I just made jump wires from the original connector to the morette ones
