Gearbox ratio's - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Gearbox ratio's (/showthread.php?tid=35163) |
Gearbox ratio's - Hdi and proud of it - 11-11-2016 Does the 206 and 406 2.0 hdi gearbox fit a 306, and also if it does, are the gear ratios the same between them, I'm looking for a low mileage one and it would give me more choice if it's on other cars too, cheers all. Sent from my F3111 using Tapatalk RE: Gearbox ratio's - madmadmax - 11-11-2016 the 406 is an ml5 so will not fit. the 206 has a box with a higher final drive so will lower engine speeds a bit , if you get the right box. i think thay both need hydralic clutch convertions tho RE: Gearbox ratio's - welshpug - 11-11-2016 406 hdi 90 is a be box RE: Gearbox ratio's - Hdi and proud of it - 11-11-2016 What box is on my 306 hdi, I mean what's its number/name, 5 speed 2 litre, is there any markings on it so I can be certain that I get the right one at the breakers ![]() Sent from my F3111 using Tapatalk RE: Gearbox ratio's - welshpug - 11-11-2016 depends on the age, could have a BE3R or a BE4 RE: Gearbox ratio's - Hdi and proud of it - 11-11-2016 Is that marked on the casing somewhere? Sent from my F3111 using Tapatalk RE: Gearbox ratio's - MY95 - 11-11-2016 It will tell you what gearbox your car has on servicebox. RE: Gearbox ratio's - Hdi and proud of it - 11-11-2016 Yes, but when I'm at the breakers, I need to be sure the metal lump thing on the floor is a 306 box and not from another model. Sent from my F3111 using Tapatalk RE: Gearbox ratio's - welshpug - 11-11-2016 look it up on servicebox it'll tell you on there what code specifically your gearbox has. something like 20bc56 or suchlike RE: Gearbox ratio's - Poodle - 13-11-2016 The standard 206 has the same ratios, it's the 2.0hdi eco model that has a longer final drive. Don't confuse it with the 206 1.4hdi eco as that definitely won't bolt on. Unfortunately the 2.0 ecos seem to be rare as hens teeth. |
