Xantia hdi 306 air box upgrade? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Xantia hdi 306 air box upgrade? (/showthread.php?tid=35065) |
Xantia hdi 306 air box upgrade? - boggs - 24-10-2016 Im wondering is an xantia air box much bigger than the standard 306 air box? I recently installed a xantia air box in my 306 as the person who owned it before had a cone filter fitted so I can't compare it for size to a standard 306 hdi air box. It was a very tight squeeze the battery tray needed a bit of modification to get it to fit although this could be due to just being an awkward shape. Thinking this could be a good upgrade? RE: Xantia hdi 306 air box upgrade? - boggs - 25-10-2016 Looking for a replacement filter they say they fit the xantia airbox as well as a 2.2 c5 so the air filter must be the same size/surface area? Can anyone shed any light on this?, |
