A/C switch fan mod - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: A/C switch fan mod (/showthread.php?tid=34126) |
A/C switch fan mod - Piggy - 21-05-2016 Bit of advice... Did search but of course no 3 word searches. So the estate... Drove it proper for first time to collect new owner...got a bit hot im traffic...no fans kicking in. Temp dropped as soon as moving. Got home. Checked AC plug...has had pins 1 and 3 bridged... But ac button on, fans do nothing. Any ideas?? RE: A/C switch fan mod - td_dan - 21-05-2016 Also can bridge 1 and 2 or 1 and 4 cant remember as one is for low speed and the other is high speed Sent from my SM-A300FU using Tapatalk RE: A/C switch fan mod - cully - 21-05-2016 to use A/C Button for Fan override Disconnect A/c pump electricily Unplug A/c Pressure switch then bridge pins in A/c Pressure switch loom side plug, one or the other not both Bridge pins 1&2 = low speed from both fans Bridge pins 1&3 = high speed from both fans if that dont work check your fans and relays RE: A/C switch fan mod - Piggy - 21-05-2016 Yeah it didnt work. Did a extra mod. But now its overheating. Great |
