gti carbs. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: gti carbs. (/showthread.php?tid=34099) |
gti carbs. - Steve 306 gti6 - 18-05-2016 hello I would like to fit bike carbs to my gti6 including manifold are there any for sale pls .thanks RE: gti carbs. - welshpug - 18-05-2016 no, dont do it. RE: gti carbs. - Steve 306 gti6 - 18-05-2016 (18-05-2016, 11:19 AM)welshpug Wrote: no, dont do it. why do you say don't do it .would you recommend some thing else. RE: gti carbs. - welshpug - 18-05-2016 throttle bodies, there is a reason there's an I on the back of cars since the Golf came out in 1978! (carbs are shit) RE: gti carbs. - miles - 18-05-2016 Carb's are fine on something's, Bike carb's thou are a backward step as the manifolds you can get are generally very poorly designed with Silicone hose joiners and the lack of people to set them up, you loose the Injectors and the throttle body is huge anyway so power wise I doubt there's much in it at all, no matter what some say. The either a Dizzy (Backwards again) or std ECU but then would need remapping or aftermarket ignition |
