Hub Nuts - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Hub Nuts (/showthread.php?tid=34029) |
Hub Nuts - Magenta Sunset - 09-05-2016 before I ask what may have been answered, is there any post ref to what size socket fits the nuts on an abs disc beam? Hub Nuts - rocker8742 - 09-05-2016 I think they're 32 but I'm not 100% Maybe check a beam rebuild guide? Sent from my iPhone using Tapatalk RE: Hub Nuts - powerandtorque - 09-05-2016 Front hubs should be 35mm (some aftermarket shafts have 36mm) Rear hubs should be 32mm RE: Hub Nuts - Magenta Sunset - 09-05-2016 cheers fellas RE: Hub Nuts - Magenta Sunset - 10-05-2016 one other question. are the threads 'handed'? don't want to be yanking the wrong way :/ RE: Hub Nuts - Frosty - 10-05-2016 As said the fronts are 35mm but most people us a 36mm six sided socket as 35mm isn't a popular size socket. No there not handed. RE: Hub Nuts - Magenta Sunset - 10-05-2016 thanks frosty RE: Hub Nuts - Mattcheese31 - 10-05-2016 As above, all the info is correct lol RE: Hub Nuts - Xsikid - 10-05-2016 (10-05-2016, 06:23 AM)Frosty Wrote: As said the fronts are 35mm but most people us a 36mm six sided socket as 35mm isn't a popular size socket. No there not handed. I got my 35mm socket from halfrauds if that helps bud RE: Hub Nuts - Mattcheese31 - 10-05-2016 Got my 35mm from Motosave RE: Hub Nuts - BiG K - 10-05-2016 I got my 35mm socket from my grandad LOL RE: Hub Nuts - Magenta Sunset - 10-05-2016 halfrauds it is then. many thanks you-all RE: Hub Nuts - Xsikid - 10-05-2016 (10-05-2016, 04:26 PM)Magenta Sunset Wrote: halfrauds it is then. many thanks you-all Deez nuts |
