Few bits - Printable Version
+--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14)
+--- Thread: Few bits (/showthread.php?tid=33984)
Few bits - Matt - 03-05-2016
Gti6 coil pack cover
Ph2/3 bonnet release cable
3 door rear seat belts. Just 2 side ones
Uprated mounts (wishbones, engine mounts)
Few bits - mcglynn - 08-05-2016
I have a vibratechnics (i think) solid lower mount.
It's damaged from me trying to bash it in instead of pressing it but it went in enough to work.
Could file the edges down and use it maybe, cant see why not.
Not really sure if its worth anything to you?
[Image: 04dea70c2bad159e1a5303d6f599013a.jpg]
[Image: 33346595b05a28e74cb51ab46a6e755d.jpg][Image: c25e0dba69973461914579331ceb6a98.jpg]
Sent from my SM-G925F using Tapatalk
RE: Few bits - Matt - 09-05-2016
What you want for it mate? I'm sure I could make it work somehow
RE: Few bits - mcglynn - 09-05-2016
Another guy mentioned £10 delivered on facebook. As long as its not like 9 quid to deliver im sure that'd be fine haha.
If you PM me a postcode I can check postage tonight when im home based on size/weight & where its going & let you know.
RE: Few bits - roland rat - 23-05-2016
Rear seat beats 20 posted for the pair
RE: Few bits - insomaniac45 - 27-05-2016
Lo fella what bits you still after? I am breaking the Ph3 cabby and have seatbelts inc clips, and bonnet release cable
RE: Few bits - Matt - 29-05-2016
Seatbelts will be diff in a cab. Will have the bonnet cable if it's good condition. Price?
Roland are you going fcs?
RE: Few bits - insomaniac45 - 29-05-2016
thats a shame Sad . but for the cable, £7.50 + P+P
whats your post code an i will get it quoted Smile
RE: Few bits - ConorTRG - 29-05-2016
I have the seat belts if you still need them.
RE: Few bits - Matt - 31-05-2016
Po37 7be
Seat belts wise, I just need the two either side, I have everything else.
And double checking they are for a 3door yeah?
Pickup from fcs?
RE: Few bits - ConorTRG - 31-05-2016
I'll not be at fcs but can post them if you want.
RE: Few bits - roland rat - 01-06-2016
Got a coil pack cover 10 posted ono
