2.2 hdi air box and maf - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 2.2 hdi air box and maf (/showthread.php?tid=33895) Pages:
1
2
RE: 2.2 hdi air box and maf - Ruan - 25-10-2016 The answer is actually kinda in my post - from what I see its a confusion over airmass rate over time vs the current cylinder charge mass... One goes up as RPMs increase, the other stays constant for the same boost level (ish... Depends on the engine's Volumetric efficiency) You don't get more accuracy between the 2.0/2.2 sensor, the accuracy is the same - it just enables the OEM to use a physically larger sensor housing whilst keeping the same resolution and compatibility between ECU software variants. RE: 2.2 hdi air box and maf - boggs - 25-10-2016 (25-10-2016, 05:12 AM)Poodle Wrote: It's not a lot different size-wise, just the shape is not so ideally suited to the space available. Looking online for a replacement air filter it says it fits the xantia as well as a c5 2.2 which leads myself to believe the filter size/surface area is the same? So therefore it is bigger? RE: 2.2 hdi air box and maf - boggs - 25-10-2016 Also is the maf and airbox we are discussing out of a 307 hdi or a 2.2 c5? RE: 2.2 hdi air box and maf - Poodle - 26-10-2016 (25-10-2016, 07:03 PM)boggs Wrote:(25-10-2016, 05:12 AM)Poodle Wrote: It's not a lot different size-wise, just the shape is not so ideally suited to the space available. Read that back to yourself and rephrase if you can, because from here it looks like you've gone full derp lol. "It is the same size therefore bigger"...? The maf we are discussing is fitted to some 110 8vs and the 2.2, various vehicles. RE: 2.2 hdi air box and maf - boggs - 26-10-2016 (26-10-2016, 05:39 AM)Poodle Wrote:(25-10-2016, 07:03 PM)boggs Wrote:(25-10-2016, 05:12 AM)Poodle Wrote: It's not a lot different size-wise, just the shape is not so ideally suited to the space available. Yes bigger than the standard 306 airbox RE: 2.2 hdi air box and maf - Poodle - 27-10-2016 Hold the filters next to each other, iirc the 306 one is slightly wider at the front where the xantia one is a touch longer. The net gain in size is slim to none. If i'm thinking of the right air filter that is. RE: 2.2 hdi air box and maf - boggs - 27-10-2016 (27-10-2016, 06:29 AM)Poodle Wrote: Hold the filters next to each other, iirc the 306 one is slightly wider at the front where the xantia one is a touch longer. The net gain in size is slim to none. If i'm thinking of the right air filter that is. I don't have a standard hdi filter to test if anyone has one lying about can they measure its area for me please. Also I may be able to source a airflow meter from an auto c5 2.2 hdi is this the correct airflow meter that use are discussing if it is the bigger version? I will messure it. Thanks for your reply RE: 2.2 hdi air box and maf - Poodle - 27-10-2016 Read the thread dude, it's been demonstrated that the maximum measured flow is almost identical between the two mafs, so it's no real upgrade. I'll try and remember to stick a tape measure across the standard filter for you tomorrow. RE: 2.2 hdi air box and maf - Ruan - 28-10-2016 It's not necessarily proven, I was just opening discussion about the subject... But then a discussion about the size of Xantia air filters started. |
