266mm Brake calipers cheap! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: 266mm Brake calipers cheap! (/showthread.php?tid=33844) |
266mm Brake calipers cheap! - BiG K - 19-04-2016 Look what I found on Amazon! Please check these parts are suitable for your 306! These should both be for 266mm discs. £15 Bosch Front right caliper: https://www.amazon.co.uk/ATE-24-3541-1768-5-Brake-Caliper/dp/B00CEFA77A/ref=sr_1_8?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461100835&vehicle=88-1796-264-12406-1-0&sr=1-8 £20 Lucas Front Left & Right Caliper: https://www.amazon.co.uk/ATE-24-3541-1757-7-Brake-Caliper/dp/B0068O54Q2/ref=sr_1_6?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461100835&vehicle=88-1796-264-12406-1-0&sr=1-6 https://www.amazon.co.uk/ABS-All-Brake-Systems-521062-Caliper/dp/B00CPNP7ZI/ref=sr_1_2?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461100835&vehicle=88-1796-264-12406-1-0&sr=1-2 Here's some Ferodo Brake pipes for a fiver each to go with your new calipers haha! https://www.amazon.co.uk/Ferodo-FHY2165-Brake-Hose-single/dp/B00CUFPUXU/ref=sr_1_4?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461104519&vehicle=88-1796-264-12406-1-0&sr=1-4 https://www.amazon.co.uk/Ferodo-FHY2087-Brake-Hose-single/dp/B00CUFOZNG/ref=sr_1_5?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461104519&vehicle=88-1796-264-12406-1-0&sr=1-5 TRW Front left wishbone incl 18mm Balljoint: £13 https://www.amazon.co.uk/TRW-JTC1055-Track-Control-Arm/dp/B00DPI059A/ref=sr_1_103?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461105801&vehicle=88-1796-264-12406-1-0&sr=1-103 Febi Bilstein front right wishbone minus balljoint: £10 https://www.amazon.co.uk/Febi-17725-Track-Control-Arm/dp/B006DHSGSC/ref=sr_1_51?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461105730&vehicle=88-1796-264-12406-1-0&sr=1-51 LuK RepSet Clutch (HDi) £30. Possibly needs release bearing (additional £30). https://www.amazon.co.uk/LUK-623307600-RepSet-Clutch-Kit/dp/B00AJWS3U8/ref=sr_1_48?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461106612&vehicle=88-1796-264-12406-1-0&sr=1-48 Rear right ph3 stock Valeo lamp £12 https://www.amazon.co.uk/Valeo-Service-086627-Rear-Lamp/dp/B00CJO8UFM/ref=sr_1_115?m=A3P5ROKL5A1OLE&s=automotive&ie=UTF8&qid=1461108305&vehicle=88-1796-264-12406-1-0&sr=1-115 RE: 266mm Brake calipers cheap! - toseland - 19-04-2016 something wrong with those if they're that cheap RE: 266mm Brake calipers cheap! - BiG K - 19-04-2016 It's sold by Amazon...return it if it is. I doubt it though, Amazon sold me a pair of front 283mm Brembo Max discs recently for £18 and those were spot on! RE: 266mm Brake calipers cheap! - mr_fish - 22-04-2016 I had a punt at the clutch ![]() ![]() Release bearing included too All seems legit. RE: 266mm Brake calipers cheap! - toseland - 22-04-2016 thing is.. I don't want to put it on the car to find out something is wrong when I am trying to slow down from 70 on the motorway for some moron that has pulled out in front of me you know? clutch is another thing.. you just break down if something goes wrong with that rather than die in a horrible twisted metal ball of pain! |
