1.1 head on 1.4 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: 1.1 head on 1.4 (/showthread.php?tid=33194) |
1.1 head on 1.4 - Adam CD P1 - 02-02-2016 Just as a matter of curiosity, has anyone ever put a 1.1 head on a 1.4 blockĀ ? I was thinking of the swap you can do on the mk3 Fiesta's where you can put the 1.1 head on the 1.3 head and it increases compression or something (can't remember exactly) but it gave me the idea. Anyone done it ? RE: 1.1 head on 1.4 - John1.4 - 02-02-2016 no point, the 1.1 and 1.4 heads are essentially identical, the only difference is the runner diameter on the exhaust iirc, couple of mm smaller, RE: 1.1 head on 1.4 - Adam CD P1 - 02-02-2016 (02-02-2016, 02:10 PM)John1.4 Wrote: no point, the 1.1 and 1.4 heads are essentially identical, the only difference is the runner diameter on the exhaust iirc, couple of mm smaller, Ah fair enough I was thinking about it and wondering why I hadn't seen anyone do it before lol cheers RE: 1.1 head on 1.4 - lolsteve - 04-02-2016 If you're looking to tune the 1.4 TU engine then have a look at the saxo boys. They will have been more likely to have done stuff with them in the saxo furios RE: 1.1 head on 1.4 - Midnightclub - 04-02-2016 Most of the saxo boys would probably just tell you to use the 1.6 16v tbh RE: 1.1 head on 1.4 - Adam CD P1 - 04-02-2016 Thanks guys I will do |
