Why would Peugeot do this? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Why would Peugeot do this? (/showthread.php?tid=33095) |
Why would Peugeot do this? - tigerstyle - 23-01-2016 XUD part at the bottom of the pic, HDI at the top, slight different offset in the main inlet from the water pump. I fitted the wrong one, and there is nothing different apart from that! Why the big change? the XUD part should even work better with the equal bolt spacing... ![]() Anyone got any other examples of Peugeot craziness where they change things for no good reason? RE: Why would Peugeot do this? - bashbarnard - 23-01-2016 same way the bolt holes for the pump bracket on the xud almost line up perfect with the bolt holes on the hdi pump bracket. but not quite. standard psa as far as i can tell RE: Why would Peugeot do this? - xudlingo - 23-01-2016 Dw8 and xud have so many difference on block like this they look so similar to Back engine mount studs pattern change just to annoy you Same with pas and alt bracket same thing Also engine mount bolts got smaller m8 Dw8s are more like hdi's RE: Why would Peugeot do this? - Toms306 - 23-01-2016 Because they like to make things awkward. ![]() RE: Why would Peugeot do this? - WiNgNuTz - 23-01-2016 Because French. /thread RE: Why would Peugeot do this? - Dum-Dum - 23-01-2016 Because Peugeot. RE: Why would Peugeot do this? - darrenjlobb - 23-01-2016 Nope, not because Peugeot.... All manufacturers do this...Infact IMO Peugeot dont do this as much as most... Consider yourself lucky that we can bolt engine/boxs from 2010 etc straight into cars from 1988 etc without modifying anything... Bolt gearboxs from a 1980's 205 straight to a 20 year newer 16v common rail engine.....cylinder heads on random engines they dont belong from many years before / after....same with manifolds...etcetc..... It can be annoying when you find little things that have changed, but in grand sceme of things, we are actually quite lucky! RE: Why would Peugeot do this? - Redordead89 - 24-01-2016 306 for the 307! Phuuuuk RE: Why would Peugeot do this? - bashbarnard - 24-01-2016 Darren actually has a fair point. The only other engine that has this as far as I know would be that zetec engine in the focus. Still using a variant of it in brand spankers' atm. RE: Why would Peugeot do this? - Niall - 24-01-2016 Agree with Darren here. Do people really think they would go through the cost and R&D to redesign things for no reason when they have off the shelf parts they could use? If they had a part they could already use, they would. Just playing devils advocate but i would imagine that the reason the lugs are offset on the bottom one is because there is a waterway in a different location on that block maybe? There will always be a reason for it! RE: Why would Peugeot do this? - Jonny81191 - 24-01-2016 (23-01-2016, 09:45 PM)darrenjlobb Wrote: Nope, not because Peugeot.... /thread TBH. Try working on german cars! |
