Which exhaust? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Which exhaust? (/showthread.php?tid=3302) |
Which exhaust? - MiiTCH - 08-05-2012 I had a new exhaust system fitted last year, standard system with a Sportex backbox... When the new cat and centre pipe where fitted, it kept coming lose, so the garage welded the cat and the down pipe... And now I want a new sportex centre pipe for my car to make it a little louder, but I'm not sure if I will need a new cat as mine has been welded, or if I cut it, the new pipe will still fit? Re: Which exhaust? - spike2002 - 08-05-2012 Carnt you grind the weld off and disconect them so then you can reuse? You may have to get it welded back up when you fit the new one ![]() Re: Which exhaust? - MiiTCH - 08-05-2012 Ill give it a go... The reason I asked this is because I need my car on the road, so I can't afford to chop it, find out its not going to fit then have to wait for the new one to turn up |
