306 xsi 2.0 2000 struggling to start - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: 306 xsi 2.0 2000 struggling to start (/showthread.php?tid=33005) |
306 xsi 2.0 2000 struggling to start - Seabrook3607 - 11-01-2016 Hello all this is my first thread and I'm new to here/forums in general, thought I'd try it out instead of struggling alone all the time lol, Anyway I just purchased my 306 2.0 xsi in moonstone blue , love the color and loving the car so far however I have a few issues but ill start with the one that the thread is for, Charged up battery as car was sat for some time before I bought it and it was very sluggish to start , This seems to have made no difference as it still struggles just the same turning over at around 1 secon per turn which almost sounds just like a dying battery but it cannot be this as I've replaced it. Further to this two times in a row now once per day, it has failed to start at all (like the immobiliser isn't registering) turning keyall electrics on but no response from starter at all, after sitting with it going off / on with ignition for around 7-8 minutes it'll decide to turn over and fire up but still with the struggle. My theory is starter motor but just wanted to be sure as it's quite odd... I've done alot of mechanics before so I'm defiantly up for the jobs it's just Ive aways been a ford man, only recently changed to peugeot, so neeneed to learn the common faults.. Sorry for long post haha. P.s alternator was making a high pitced whine for first couple of days but this *seemed* to go away... RE: 306 xsi 2.0 2000 struggling to start - adam b - 11-01-2016 Battery terminals tight? Earth points esp gearbox top good and clean? Usually the earth points... RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 11-01-2016 You know what I hadn't thought of that I will check there first but doesn't it seem at all like starter to you? Terminals are tight but ill check the earth's RE: 306 xsi 2.0 2000 struggling to start - roland rat - 11-01-2016 As adam said battery terminals, then earth's and then crank sensor I'd say RE: 306 xsi 2.0 2000 struggling to start - adam b - 11-01-2016 Measure your voltages across different points, then cranking voltages. Could be the battery isn't good too. These do suffer with poor earth points though. Crank sensor would make it not start, but it wouldn't make it sluggish and it'd cut out if the signal disappeared RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 11-01-2016 Well as I've said battery being duff isn't really my 1st guess as sometimes it'll not turn over at all but then a few try later it will turn over fine , that's the bit that's thrown me a bit RE: 306 xsi 2.0 2000 struggling to start - roland rat - 11-01-2016 (11-01-2016, 10:42 PM)Seabrook3607 Wrote: Well as I've said battery being duff isn't really my 1st guess as sometimes it'll not turn over at all but then a few try later it will turn over fine , that's the bit that's thrown me a bit I'd say crank sensor then RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 11-01-2016 Ok cheers ill give it ago RE: 306 xsi 2.0 2000 struggling to start - andywhy - 12-01-2016 (11-01-2016, 06:23 PM)Seabrook3607 Wrote: P.s alternator was making a high pitced whine for first couple of days but this *seemed* to go away... Check that the alternator hasn't seized up and that this isn't the cause of your slow cranking? RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 Thanks guys managed to get it sorted by cleaning up all the earth points and terminals! However that's not the end of the troubles lol should I set up a new post? RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 Whats up with it? RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 Cambelt sounds like a mouse is stuck in it , going to be needing to do rear axle soon , lacks power for a 2ltr xsi it's not very great with acceleration , and exhaust sounds like has a blow in middle but pressure is perfect. couple more bits too but got to think lol RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 (12-01-2016, 05:38 PM)Seabrook3607 Wrote: Cambelt sounds like a mouse is stuck in it , going to be needing to do rear axle soon , lacks power for a 2ltr xsi it's not very great with acceleration , and exhaust sounds like has a blow in middle but pressure is perfect. couple more bits too but got to think lol Cambelt is either too tight or tensioners are on their way out. Rear beam is a simple thing just find a tidy one.exhaust is another easy one to rectify,and down on power could be a few things RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 I know the only one of those I'm not exactly clued up on is cambelt , can't say I've done one before I know what it's all about etc but haven't done one in one of these. And the fact it's whining is a very bad sign right ? Fact it's down on power could be alot I know but not sure exactly where to start! Runs smooth as a di just seems to be a hit underpowered in my opinion , (could just be me as I'm used to a little polo gti at 135 bhp that thing flew) it's not slow just I'm sure it should be quicker of the button than it is RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 Cambelt isn't that difficult tbh and yes the whining is good a good thing! I'd start at the basics like a good service including spark plugs them look at things like sensors etc And the polo was lighter so would feel quicker than the XSI RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 Yes I've just done the service and she loved that , much smoother running now , it's the cambelt I'm most concerned with now I've done clutches etc so done hard work but just haven't done a cambelt but I want to do It RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 All I can say is make sure you've pinned it up right and the bottom pulley hasn't slipped.once you've done that it's no more difficult than any other 16v engine. If the timing is out that could be the cause if lack of performance RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 Could do with a Haynes for this one o reckon , as I say I'm not sure on how to do a cambelt , confident I could do it but need to know the procedure.. RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 Also look for auto data on it.tbh it's the same engine as the gti6 so there's an FAQ on the 306gti6 forum on the cambelt change RE: 306 xsi 2.0 2000 struggling to start - Niall - 12-01-2016 The bottom pullies have a habit of slipping meaning you may accidentally time it up wrong. Before you do change the belt, have a good look at the pulley. There should be two arrows that should line up. If they dont, pulley has slipped and dont even think about timing it. RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 Yeah I know if they don't line up then if you time it there it'll bust the engine up I'm aware of that just not sure of the procedure is all, so what causes it to make the high pitch whine it makes , it comes and goes :/ RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 (12-01-2016, 08:57 PM)Niall Wrote: The bottom pullies have a habit of slipping meaning you may accidentally time it up wrong. Before you do change the belt, have a good look at the pulley. There should be two arrows that should line up. If they dont, pulley has slipped and dont even think about timing it. ^^ This!! If it has slipped I'd recommend a soild pulley ad they are the same cost as a pug one. RE: 306 xsi 2.0 2000 struggling to start - Niall - 12-01-2016 Could be a bearing on its way out (notice it does it at all when the engines warm or cold?) or it could be the belts too tight but you only notice it once warm because the engine generally quietens down. RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 I'm not understanding the pulley slipping part of it ![]() RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 (12-01-2016, 09:09 PM)Seabrook3607 Wrote: Yeah I know if they don't line up then if you time it there it'll bust the engine up I'm aware of that just not sure of the procedure is all, so what causes it to make the high pitch whine it makes , it comes and goes :/ Could be a failing bearing in a tensioner or the belt itself rubbing on part of the cambelt casing. (12-01-2016, 09:11 PM)Seabrook3607 Wrote: I'm not understanding the pulley slipping part of it The bottom pulley is made up of a metal inner section, a rubber 'damping' middle section and another metal outer section.over time the rubber deteriorates and it slips on the inner metal part. RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 I see , so it's possible I may well need more than just a cambelt kit then RE: 306 xsi 2.0 2000 struggling to start - Seabrook3607 - 12-01-2016 So does the cambelt run the water pumps on these ? And does a bearing/tensioner come in cambelt kit? I'm not sure as never had to buy one P.s sorry to come across as a dumbass just haven't had to do a cambelt yet is all RE: 306 xsi 2.0 2000 struggling to start - roland rat - 12-01-2016 Yes cambelt runs the waterpump and there is 2 tensioners in the kit. The kit is cheap enough at Euro car parts.just picked one up for my GTI6 for less than 60 quid |
