206 1.4 8v Cutting out - Printable Version
+--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18)
+--- Thread: 206 1.4 8v Cutting out (/showthread.php?tid=32981)
206 1.4 8v Cutting out - ct-hdi - 08-01-2016
Having some problems with the mrs 206.
When reversing off the drive or generally moving especially from cold it has a tendency to cut out. As though the revs drop too much. Starts up fine after. But can do it again if you aren't careful.
Has occasionally just cut out while driving aswell. Also, can run fast as though it's on cold start...
Temp gauge seems to be working as it should warming up quickly and sitting at 90-100 degrees...
Exhaust blows between front and center pipe but will be sorting this asap...
Anyone any suggestions? Or is it likely to be just because of the blowing exhaust messing with the emissions?
