Fitting a hdi box to a dturbo - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Fitting a hdi box to a dturbo (/showthread.php?tid=32888) |
Fitting a hdi box to a dturbo - Craggs2010 - 28-12-2015 So swapping over gearboxes today what a pain anyway going to build it up tomorrow do I use dturbo clutch or the hdi one? RE: Fitting a hdi box to a dturbo - Paul_13 - 28-12-2015 I'd stick with the dturbo clutch setup. Means swapping the clutch arm over Means you haven't got to change the clutch cable either Fitting a hdi box to a dturbo - Craggs2010 - 28-12-2015 Can it be run with hdi clutch if the cable is swapped over? RE: Fitting a hdi box to a dturbo - Paul_13 - 28-12-2015 You'll need to swap the flywheel to a hdi fly wheel as it's a bigger diameter) ,source some clutch cover bolts (different size to dturbo) and replace the flywheel bolts with new ones (don't reuse old ones) Hdi flywheel weighs over 4kg more than a dturbo flywheel RE: Fitting a hdi box to a dturbo - bashbarnard - 28-12-2015 also youll loose the rev counter that way as well RE: Fitting a hdi box to a dturbo - Dazecoop - 28-12-2015 Sucks to have those text's from you today mate, sounds like it wasn't going as planned! This is interesting to know though, as I'm hoping to do a clutch change & HDI gearbox upgrade on my D Turbo at some point. Best method then -- HDI gearbox, swap fork over from D Turbo Use D Turbo flywheel & clutch Use D Turbo clutch cable Use all original D Turbo bolts? Is that all correct? RE: Fitting a hdi box to a dturbo - maxlee - 28-12-2015 /\ thats what i did also need the clutch cable holder part of the xud box RE: Fitting a hdi box to a dturbo - Ruan - 29-12-2015 (28-12-2015, 10:27 PM)Dazecoop Wrote: Sucks to have those text's from you today mate, sounds like it wasn't going as planned! Correct, as above, you need the clutch cable holder, but this is already on your DT box. Also, whilst you're at it, replace the plastic nylon bushes the fork sits in, these wear and make the clutch feel like turd, it's not a bad shout to change the cable (and obvs clutch) whilst you're at it - it'll feel like new after that. RE: Fitting a hdi box to a dturbo - Dazecoop - 29-12-2015 (29-12-2015, 12:45 AM)Ruan Wrote:(28-12-2015, 10:27 PM)Dazecoop Wrote: Sucks to have those text's from you today mate, sounds like it wasn't going as planned! Cool, cheers. Good to know! Fitting a hdi box to a dturbo - Craggs2010 - 29-12-2015 New clutch has just arrived time to rebuild hope it all goes well today Fitting a hdi box to a dturbo - Craggs2010 - 30-12-2015 Omg after all the sore fingers and broken parts I'm finally back together and going good had it out a good blast there and I must say its well worth changing to the hdi box I love it!!!!! |
