Black smoke - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Black smoke (/showthread.php?tid=32877) |
Black smoke - Matt - 26-12-2015 Rallye runs absolutely fine, little tiny bit hesitant this morning and revs hang slightly but shortly after it cut out (icv related) But went out in a local cruise tonight and whilst giving it some I'm told it puffs black smoke after gear change. I was taking it pretty much too the redline. I don't do this often so could it just be build up of soot/crap is the exhaust/engine been burnt up? I'm hoping it doesn't mean the engine is terminal RE: Black smoke - adam b - 26-12-2015 It's normal. They overfuel a lot at the top end of the revs. RE: Black smoke - 7057sam - 27-12-2015 Today for first time in ages (3 months maybe ) I gave it abit of a trash,as it's been my daily commute I rarely go above 3k but gave it full on beans and yeah proper stunk of fuel I guess that just normal. RE: Black smoke - Toms306 - 27-12-2015 I said about this with mine, was getting a black exhaust tip after a couple of days with hard driving... Someone (possibly Niall?) said they inject some fuel on gear changes for piston cooling iirc. RE: Black smoke - lolsteve - 27-12-2015 They do seem to run very rich at the red line. On track they're often puffing RE: Black smoke - ginge191 - 27-12-2015 Yep - normal. But i doubt it would be black smoke. Im assuming this was the evening drive and would've been dark? Someone may have seen it in their headlights? RE: Black smoke - Matt - 27-12-2015 Okay it's put me at ease a little! Yeah it was last night up the dual, apparently I looked like a diesel RE: Black smoke - Niall - 27-12-2015 Depends how much. A bit of a puff of black smoke is normal from these but you say like a diesel....If its like most of the XUDs on here then you have a big problem lol RE: Black smoke - Toms306 - 27-12-2015 But if its like a DPF equipped diesel then there'll be no problem at all... Like a diesel isn't a good enough analogy!
RE: Black smoke - Matt - 27-12-2015 It's probably just a puff, I can't see it in the rear view so it can't be that bad. The guys I hang around with do like to exaggerate haha |
