Tappet problem - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Tappet problem (/showthread.php?tid=32861) |
Tappet problem - camoturd - 23-12-2015 Very noisey tapping noise on start up and tick over I did look and it sounds alot like tappet. Question is how hard to do and should I change injectors at same time? RE: Tappet problem - toseland - 23-12-2015 it is likely just the injector, got a vid of the sound? RE: Tappet problem - camoturd - 23-12-2015 No as cant figure out video upload RE: Tappet problem - toseland - 23-12-2015 youtube then post a link easiest RE: Tappet problem - camoturd - 23-12-2015 https://youtu.be/-QJsbdG2oMA This is what it sounds like Its not mine but sound very very similar RE: Tappet problem - C2K - 23-12-2015 Watching on my phone but Crank Pulley OK? RE: Tappet problem - camoturd - 23-12-2015 Not sure but cambelt was done 7 months ago but to tell the truth I not sure done well Ok so here is the noise from mIne https://youtu.be/UK6ATLhuKuE RE: Tappet problem - toseland - 23-12-2015 doesnt sound regular enough to be tappets, unless one of them is literally flapping around without any sort of guidance in the head, i would hazard a guess at a pulley too, someone with a lot more experience should be along anytime soon (poodle? lol) RE: Tappet problem - C2K - 23-12-2015 Have a look at the pulley, it might be obviously eccentric or showing bits of shiny metal. RE: Tappet problem - camoturd - 23-12-2015 Is it ok to drive with it as cant get one done till next year RE: Tappet problem - HDi--Power - 23-12-2015 I wouldn't drive that car another inch until its been properly checked out RE: Tappet problem - Poodle - 24-12-2015 As above. That's almost definitely crank pulley, get it checked and changed now before it takes the cambelt with it. Bring it up to me today if you like, i'm not working and can sort it out immediately, will drop you a pm. |
