| What pipe is this? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: What pipe is this? (/showthread.php?tid=32708) |
| What pipe is this? - insomaniac45 - 07-12-2015 Sorry no pics as of yet, but should be able to get one tomorrow. Ok, so its on the cabby, 2.0l 2000 plate. While under the car identifying what tools i need to drop the oil, i noticed a pipe running under the sump, it is metal and goes from front to back. but where the casings meet, the pipe seems to be touching and there is evidence of fresh oil. So i presume best case is the pipe has got a slight leak from it touching. Is this the oil feed pipe? if so, has any one got a good one going? this thing is getting silly on the parts now. Just ordered a whole list of niggles........... RE: What pipe is this? - powerandtorque - 07-12-2015 Sounds like the high-pressure power steering pipe to me - one end should go to the PAS pump, the other end to the steering rack. RE: What pipe is this? - insomaniac45 - 07-12-2015 humm. that is just as bad if it is leaking then........ but, if i feel the fluid, i should be able to tell instantly if it is engine oil, or hydraulic oil i suppose. Thanks for the info   Tony. RE: What pipe is this? - Niall - 07-12-2015 You can smell it instantly if its hydraulic oil. When they leak down the hose like that, the oil normally ends up utterly filthy. RE: What pipe is this? - insomaniac45 - 08-12-2015 good news........ the pipe is not leaking.... bad news is i think its the main seal. Its only a light seepage, so should be ok till early next year when i plan on a full clutch change. so it will have to wait till then.   to top that off, the off side driveshaft seal is seeping too. |
