gearbox changing - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: gearbox changing (/showthread.php?tid=32476) |
gearbox changing - Steve 306 gti6 - 09-11-2015 Hello just recently bought a 306 gti6 would like to change gearbox from a 6 speed to a 5 speed, can I use the be3 gearbox from a zsara gti gearbox changing - Janne L - 09-11-2015 Yes you can. RE: gearbox changing - Steve 306 gti6 - 09-11-2015 (09-11-2015, 02:47 PM)Janne L Wrote: Yes you canThank you Would I be able to use the gti6 clutch or clutch from the zsara gearbox changing - Janne L - 09-11-2015 Is it a xsara vts? AFAIK there is no xsara gti, it's called vts. If the answer to my question is yes, then the clutch will be identical. RE: gearbox changing - distinctionx - 23-11-2015 (09-11-2015, 06:58 PM)Janne L Wrote: Is it a xsara vts? AFAIK there is no xsara gti, it's called vts. What would he gain in changing the gearbox?? (6 speed vs 5 speed) (Newb) RE: gearbox changing - Steve 306 gti6 - 24-11-2015 I've been told that the gearing would be better for sport as a six speed box is not the best . RE: gearbox changing - C2K - 24-11-2015 I use the 5 speed Xsara Be3 box on my Rallye, i prefer the ratios. Standard GTi6 clutch. RE: gearbox changing - welshpug - 24-11-2015 nothing wrong with the 6 speed unit other than not being quite as strong. xsara vts uses the same clutch,. its a direct bolt on, just don't use the reverse strop cable. |
